Question about Mitsubishi WS-55513 55" Rear Projection HDTV
Model # ws65813 how to self diagnostic please
Same blinking light won't turn on WS65813
Re: model # ws65813 how to self diagnostic please
All the info you could ever want is here:
Posted on May 08, 2009
Re: model # ws65813 how to self diagnostic please - Mitsubishi WS-55513 55" Rear Projection HDTV Projection Televisions
Ws 65813 blinking light please help
Posted on Dec 03, 2008
    An expert whose answer gotĀ voted for 100 times.
  • 317 Answers
Call tech and suggest ....c chip
Posted on Nov 26, 2007
0 characters
3 Points
When I turn on the tv all i get is the welcome screen, and it will not go any futher,there is green light flashing in front of the tv. and it will not turn off with the remote, i have to unplug it.
Hi Andre,
May I know if the LED light at the front panel has a pattern of flashes or flashing continuously in green color.
Please check if you can access the "Self diagnostic screen" by following the steps below.
- To activate, press the front panel "Activity" and "Channel down" buttons at the same time and hold for 5 secs. The Status led will then flash a two digit code. Example, if the error code is "23" the led light flashes 2 times(blink, blink) pause and then flash 3 times(blink, blink, blink). Let me know the error code to narrow down, it will help to diagnose where the fault came from.
Note : the TV must be in shutdown not switched off, or AC power cord is removed because the code will reset to "12" means no error. Use the front panel buttons not on the remote control. If you can't access the self diagnostic, press and hold the "Activity" button on the front panel for 5 secs before entering the "self diagnostic" code.
Nov 24, 2011 | Mitsubishi WD-60737 TV
Green power light blinks, and TV comes on, and goes out, and power light goes red
Sounds like a problem with the power supply. After it shuts off do any other lights blink, apart from power LED turning red? Please provide this info as it is a self-diagnostic code that will help identify the problem.
Sep 16, 2011 | Sony KDS-55A3000 55" HDTV
Contstant blinking green light on Mitsubishi ws65813 projection tv
u have bad dm board , this board look like a cable box , when u open the back cover of ur tv u would see this box , u have to replace about 7 capaciotors on this box , the capaciotor are on the small boars inside on this box 1000Uf at 16 volts , but if u have no idea on how to replace this cap u can hire a tv tech nowmal repair is about $250
Nov 02, 2010 | Mitsubishi Projection Televisions
Blinking green light on mitsubishi ws65813 tv i replacec the capicators but last time a tech had to replace a fuse too. where is the fuse?
On the power supply board near the connectors for outputs. Probably a 'pico' fuse which is small and soldered in - looks like a solid colored smaller resistor, usually.
Apr 11, 2010 | Projection Televisions
Green light flashing
The WS65813 is the V23++ series. The blinking led means the DM caps have failed you can get the V23 DM repair kit at the following link which contains the replacement capacitors and step by step instructions with pictures so you can do the repair. Heres the link its listed under the repair kits category.
Feb 16, 2009 | Mitsubishi WS-65813 65" Rear Projection...
Mitusbishi WS65813 blinking green light
You have a defective power supply and/or DM board, usualy are bad caps 1000 uf 16v, if after replacing all caps the problem persist you will need to contact mistsubishi and send the chassis for repair.
Jan 16, 2009 | Mitsubishi WS-65513 65" Rear Projection...
Mitsubishi WS65813 Rear Projection TV. Main power board is bad,
they are no longer available from mitsubishi or the distributors. You may be able to get the board remanufactured at the following link. Just leave them a email with the part number.
Aug 31, 2008 | Mitsubishi WS-65513 65" Rear Projection...
Check threads for DM repair or
Jan 04, 2008 | Mitsubishi WS-55513 55" Rear Projection...
TV is Mitsubishi 65" Model #WS65813, Serial #NWPROJ4K-5 (Diamond Series).
That particular board is NLA - - - the only way to have it repaired besides a local shop is to send it in to PTS Electronics for rebuild but I'd call them first and make sure they support it.. That's from a V23 chassis and that particular board was used in many PTVs in the Mits line-up.
PTS is 800-844-7871
Good Luck!
Dec 17, 2007 | Mitsubishi WS-55513 55" Rear Projection...
Mitsubishi ws65813
Dec 12, 2007 | Mitsubishi WS-55513 55" Rear Projection...
Mitsubishi WS-55513 55" Rear Projection HDTV Logo
301 people viewed this question
Top Mitsubishi Projection Televisions Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Projection Television Expert? Answer questions, earn points and help others
