Question about Sharp 27H-S60 TV
Has sound but no picture
My TV has sound but no picture. For a period of time the screen was wild but when I tapped the tv it worked fine. However now there is no picture but I do have sound.
  • 281 Answers
That could be a dry soler joint, most probably as you said it used to work when you tap. Now the joint might have gone worse. Check the pcb for dry joints and resolder them. Good luck.
Posted on Jan 24, 2008
I have a Westinghouse SK-32H240S 32" flat screen
First when tapping changes the picture you have somewhere a bad connection; in electrical board or wiring.
When the screen goes blank after a while means some capacitor is bad/old.
Mar 13, 2011 | Westinghouse SK-32H240S Television
I have a Toshiba cx35e70 tv. The problem began as a turn on, live screen, no channels, no sound. I found that when I would tap on the tuner on the main board the problem would disappear. Every thing worked...
Is the VCR going through ch 3 or video inputs - if video inputs your TV tuner is likely bad if through ch 3 seeif te picture goes funny on ch 3 without using the VCR the tuner may be bad on higher band channels - smetimes you can remove the tuner and resolder the tuner itself. But if it always works with the VCR just use it that way and don't bother with the fix.
Sep 26, 2009 | Televison & Video
Horizontal Line through middle of TV screen
This is usually a bad elect capasitor or a bad solder connection on the vertical IC, The capasitors will be close to the vert chip..Sometimes you can clear problem with a light tap on the TV, if so then suspect bad solder.
Mar 31, 2009 | Televison & Video
Jvc av27d201 tv screen problem
You need to have the vertical output IC pins resoldered
Jul 16, 2008 | JVC AV-27D201 27" TV
No picture but has sound
switch on no picture but short period of sound then nothing
Jan 20, 2008 | Sony KP-51HW40 51" Rear Projection...
Pip screen and tv screen wont produce a picture at the same time
Order a new TV....thats what I have to do. I have the Protron 42", and I cant get any sound, and I cant get the remote to work. Figures, too.....the TV JUST passed its warranty period by 4 days! I havent seen any positive things said about this company, either.
Nov 04, 2007 | Protron PLTV-32 Television
hello .this does sound like bad solder joints .all printed circuit boards do this after a while due to heating and cooling .is not advisable to try to repair yourself .possible electric shock and spiking .will do a lot of damage .take to a shop to have repaired
Oct 30, 2007 | Sony KV-36XBR450 36" TV
Vizio GV42L LCD TV screen black when turn TV on first time
If you are using a set top box this might be caused by turnig the box on at the same tie as you turn the tv on or slightly after you turn the tv on.  If you are using compnent or HDMI inputs the set needs to see the signal as it is turned on to know what formt the signal is in.
Oct 15, 2007 | Vizio P2 42 in. HD-Ready Plasma Television
Picture takes hours to appear
Spounds like the b+ feed filter capacitor off the flyback that supplys voltage to the three drive transistors on the crt board is bad.
Apr 16, 2006 | Sony KV-32V16 TV
Televison & Video Logo
319 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
