Actually it depends. Which LED is it, lamp, timer, power?
Depending which one it is, it will be the issue, if it's the on for the lamp, it's most probable that you may need to replace it sometime soon, if it's the timer, you need to reset the lamp timer, and if it's the power button, well you'll need to put attention to what other symptoms you can notice on the TV
Was this helpful?
Yes
No
Popular Solutions for Panasonic PT-50DL54 50 in.
Panasonic PT-50DL54 50 in. Rear Projection HDTV-Ready...
i cant get a picture on my hdtv. i just replaced the lamp and i still ant get a picture on my...
(More)
i cant get a picture on my hdtv. i just replaced the lamp and i still ant get a picture on my Panasonic pt-50dl54
After replacing the lamp i get a flashing green light and no power up? Do I need to reset something...
(More)
After replacing the lamp i get a flashing green light and no power up? Do I need to reset something or trash the TV. When I called Panasonic they told me to purchase a new part a $1800. there wacked, i'll put it in the trash and will Never purchase anything from them again.
I have a Panasonic PT-50DL54J DLP projection TV. It suffers from a shut down problem. Shortly...
(More)
I have a Panasonic PT-50DL54J DLP projection TV. It suffers from a shut down problem. Shortly after powering up, the TV shuts off, and the front LED flashes red 6 times. At this point, the TV will not turn on. Unplugging the TV seems to reset this and allows me to turn the TV on briefly, then it shuts down again with the flashing light.
