Filter care light flashes even after filters are clean
SOURCE: my candy civ60 dryer dose not heat
hi i too had that problem,when an engineer looked at it the thermostat,element were ok,he suggested that there was a blockage in the air flow,i took the whole thing apart ( i had nothing to lose ) cleaned it with a hoover very carefully then with a clean dry paintbrush,there is vents underneath the dryer if these get blocked the dryer blows cold air, its a saftey measure so that the fluff dosent catch fire ! i hope this helps,mine has run ok for 3 months now.
SOURCE: Bosch Axxis WTL 5400 Electric Condensation Dryer...Lint Filter Light
have you checked the vent line it could be stopped up if the line is bent same affect as the lint filter being full
SOURCE: Candy CIC60 01 Tumble drier
Hi you need a new heating unit which is behind the back casing. Price approx £42 plus labour
SOURCE: Bosch Nexxt 500 Electric Dryer: lint filter light goes on even though it does not need emptying
I had the same problem and figured if the lint sensor is clogged, covered or otherwise gummed up with lint, dirt, hair, etc then this will continue to happen regardless of wether the lint trap is clean.
So I took my compressor and blew out the slot where the trap slides into...stuff flew everywhere (so watch your eyes or wear goggles). I then vaccumed it up and did it again... and again and again each time loads of stuff came out. Once nothing blew out I loaded the dryer and have not had the problem since...
This makes sense right? so if you can try this solution.
SOURCE: Tumble Dryer not getting hot
thermister i.e thermostat in located just in side of fillter housinfg damaged replace i
