Question about Maytag MER6772 Gemini Electric Kitchen Range
Maytag MER6770 F1-3 code Serial #12650733ws
Both ovens locked after cleaning, any suggestions?
  • Samoth Dec 17, 2007
    your suggestion was correct about the sensor being bad, I now have an F9-4 code showing when we turn the clean on either oven. we have been out of town since you returned my request.It seens to have something to do with the lower oven lock. any suggestions would be helpful.
  • Anonymous Mar 18, 2014
    top oven not working
  • 290 Answers
F1-3 is the code for the upper oven being over 950 deg F.
If the oven is now cool, then most likely there is a problem with the temp sensor in the upper oven.
You will need to remove the rear panel from the stove and check the resistence of the sensor to know for sure if it is bad. The only other way is to hook a new sensor to the harness and see if doors will unlock then.
Post back if you have any questions.
Posted on Nov 26, 2007
  • Michael  Lindley
    Michael Lindley Dec 04, 2007
    Just wanted to follow up on your oven problem and see what you found out.
Model CRE9600CCM Serial 24625851SK. When we turned on the oven, we got an error message "F-5". What does this mean? What do we need to do?
Here is a list of codes for Maytag-- Does this help:
Maytag / MAYCOR / Magic Chef / Jennair / Admiral
Oven Fault Codes
Display Condition Remedy
F0 Function key shorted or stuck button Clean and unstick button or replace Touch Pad or Clock
F1 Defective Touch Pad or Membrane Replace Touch Pad or Membrane
F2 Oven over heat defective Relay Board or (if present) or defective Sensor
F3 Oven Sensor Open Replace Sensor
F4 Shorted wire or Sensor locate short and correct it or replace Sensor
F5 Hardware, safety circuits disagree Replace Clock
F6 Missing AC (power) signal Check for proper voltage (plug, breaker, etc.)
F7 Function key shorted or stuck button Clean and unstick button or replace Touch Pad or Clock
F8 A/D Warning Replace Clock
F9 Door Lock Warning Check door lock circuit or Replace Clock
Let us know if we canhelp further,
Mack B
Jan 23, 2011 | Maytag Ovens
Getting Error Code f9-5 and f9-6 on MER6770
This is a bad electronic clock assembly and it is very simple to repair. You can save a lot of money by making this repair yourself, too!
Just contact us at: from 7 AM until 7 PM CST and we will get the correct part, as well part removal/installation instructions to you .
We look forward to working with you. Thanks, Ella
Jan 18, 2010 | Maytag MER6772 Gemini Electric Kitchen...
Purchased at Maytag Gemini MER6770 in 2000. It
Sounds like the cancel (or stop) button is making contact by itself. Clock (oven control board) may need replacement.
One option to buy it new, your part number is 12001661
Coupon "New10" chops 10% off.
Another is to send the clock to be rebuilt. Google "stove timer rebuild", you'll find plenty of companies which can repair your original clock. In case you need it, the original part number is 74004542.
To get to the clock, remove the back of the control panel. Good luck.
Oct 24, 2009 | Maytag MER6772 Gemini Electric Kitchen...
Bottom oven lock will not lock to clean my Gemini model MER6770
The lower oven may have a problem . It could be a few different things the door latch mechanism, oven door switch, the metal rod that pulls the latch over all are quite difficult to figure out. I would recommend calling an authorized servicer on this one. good luck
Dec 22, 2008 | Maytag MER6772 Gemini Electric Kitchen...
Maytag stove will not open after cleaning
is the oven completly cooled down? the latch is hat sentisive the oven must be cool before the latch will open this can be from 15 min to 2 hours after the clean cycle is complete
Aug 25, 2008 | Maytag MEW6630D Electric Double Oven
Door safe luck
You will have to replace the door latch assembly.It is difficult to release the latch if it jambs closed.You have to have the experience to do this or you will just make matters worse.
Aug 25, 2008 | Maytag MER6772 Gemini Electric Kitchen...
Maytag top oven lock won't lock
Do you get any error codes? What shows on the display when you try? does it make any noises , like it is trying to lock? Is it a manual lock with a lever?
Jan 19, 2008 | Maytag MER5775Q Electric Kitchen Range
MER6770 Fault Code
No. just the one sensor part number 12001656. After paying a maytag repairman twice, I will now for the third time replace it myself, google the part number and you will see the different companies that sell it. Price runs up to 40.00, next time buy a different product and hope that Maytag goes out of business!!!! I know I will!!!
Dec 17, 2007 | Maytag MER6772 Gemini Electric Kitchen...
Maytag MER6772 Gemini Electric Kitchen Range Logo
278 people viewed this question
Top Maytag Kitchen Ranges Experts
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
