Question about RCA 32V524T TV
RCA 32v524t About a year old and Quit working all I get is some ticking and a green flashing light out of warrany so I opened it up. I notice when I plug it in and hit the power button the tube lights for about a 1/2 a second then goes out then the power light starts flashing. I suspect that the flyback transformer is failing under a load. I would love to hear any other Ideas before I yank it out.Thanks,Chris
  • RucsteR Dec 24, 2007
    We have had this RCA 32v524t for 1 yr 3 monthes. Then the power is turned on, relay toggles once and power light (on the on/off button) blinks. After a few second, power light stays on. There in no picture and no sound. When I contacted RCA, they said call Thomson. I called Thomson and they stated that the warranty is over so there is nothing they will do. It appears RCA has an issue with Thomson parts and RCA is not standing behind their product!
  • rabr26 Apr 16, 2008
    my wife turned the tv off. i went to turn it back on about 30 min later and all that happens is green light flickers on and off for a few seconds then stays lit but no picture or sound. the tv is only 4 months old and the warranty through badcock has expired
  • 1,139 Answers
Hello All,
This is a flyback problem. Thomson will not honor the installation neither will RCA. This has been going on for years. RCA and Thomson technically parted company a few years ago, but because RCA still uses Thomson parts they often have problems getting these parts when they fail, so RCA leaves it up to the TV owner to get the set repaired at a third party shop. In addition to this the Thomson parts only have a 1year warranty from the date of manufacture of the set, so it is possible for you to buy a RCA TV with Thomson parts that are out of warranty before you take it out of the store. Sad but true, the only recourse is to try to get RCA to service the set, provided that it malfunctions within the first year of purchase. I would suggest that you all take these TVs to a qualified TV repair shop to get them repaired, however, make sure the shop uses the exact OEM parts (This is important) because there are parts that come close to the original, but you or the TV shop would have to spend hours adjusting focus and screen voltages to allow the new part to work.
I hope this helps
Thank you,
Posted on Jun 02, 2008
My 37 in rca, model # L37WD12, Will not fully turn on. it tries to come on, but the green light just flashes. and the tv makes a small ticking noise that goes with the flashing. how do i fix this or what...
The inverter is probably bad - the ticking noise you hear is high voltage that is trying to turn on the backlight from the inverter's transformer but cannot. The only way to fix this is to open the TV and locate the problem around the inverter circuitry. Another possibility is there is an open circuit run around the inverter and may just need some solder to bridge the open.
Jan 16, 2011 | RCA L37WD12 37 in. LCD HDTV
My RCA television quit all of a sudden and now the power button is flashing green and won't turn on.
Your tv has a power supply fault, take it to repair shop and have it repaired
ask the technician to check the following components
semi conductors around the supply section, also ask him to check the (ht) high tension voltage which triggers a line transformer which in turn gives small outputs voltages to power the tv.
Jan 03, 2010 | RCA 32V524T TV
Tv wont turn on, red flashing light
Apr 11, 2009 | RCA 32V524T TV
RCA, rear prjetion, 46" tv,no power, ticking sound
Ticking is usually related to the horizontal output and the flyback with the flyback being more suspect. If you need more assistance please let me know
May 13, 2008 | Televison & Video
check this thread
May 12, 2008 | RCA 32V524T TV
Just quit working
Looks like either the auto transformer or the flyback is defective. I recommend consulting a qualified technician.
May 07, 2008 | Televison & Video
This may denote a proble in either your switching powers supply or your Horizontal section derived high voltage power supply. These are both very dangerous sections in your television. My next question is important; do you have a background in electronics? If not I would not advise you working on this problem yourself and that you take the TV to a repair shop for servicing. If you do have some background in electronics, I would like for you to make the following obeservations: What was the TV doing (it actions)prior to it going out? Did you hear any sounds before it went out like buzzing or crackling? What do you hear when you try to turn it on now, clicking? These questions are just to develop some background into what might be happening to your set. Thank you, Shuttle83
Oct 07, 2007 | RCA 32V524T TV
RCA 32V524T
Probable EEPROM issue--What is the service #? (Has three additional characters after model #. EXPERIMENT==1)remove EEPROM-be careful not to damage it. 2)Install 8 pin plug-in socket--observe pin 1 indicator. 3)Plug back in original IC==may work ok,if not replace w/pre-programmed IC from HB Electronics.
Oct 03, 2007 | RCA 32V524T TV
RCA 32V524T- Blown fuse?
If you blew the fuse, the TV would do absolutely nothing - no lights, no sounds, nothing. It could be that the loud zapping noise you heard was the high voltage transformer arcing or shorting out. This could have caused the horizontal output transistor to short, and the set will not start as a result. You should have the set serviced by a qualified tech.
Sep 01, 2007 | RCA 32V524T TV
Television will not turn on
look on the rear of the set and find out what chassis in your set.
Aug 30, 2007 | RCA 32V550T 32" TV
RCA 32V524T TV Logo
134 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
