Your burner is not lighting completely, this may result from some contamination on the burner itself. Try cleaning any contaminants with a stiff brush, like you would use on a barbecue grill. Be very careful not ot make contact with the igniter as you will break it if you do. BTW, while most gas appliances are very safe to operate, I consider this one to pose a danger if it is not corrected.
Was this helpful?
Yes
No
Popular Solutions for GE Profile Spectra JGBP90 Gas
forgot to unplug stove before removing the heating element in the oven. the hot feed wire to the...
(More)
forgot to unplug stove before removing the heating element in the oven. the hot feed wire to the heating element shorted out on the side of the oven. Now the oven and top burners won't work.what could be the problem?
I am not able to bake in the oven. Everytime I try and preheat the oven the clean light keeps...
(More)
I am not able to bake in the oven. Everytime I try and preheat the oven the clean light keeps flashing. I ran it twice through the clean cycle but it still is flashing now what?
The tubing from the knobs to the burner cracked! I was cooking and there was this loud boom and...
(More)
The tubing from the knobs to the burner cracked! I was cooking and there was this loud boom and flames. I immediately turned it off and checked under the top and found the tubing cracked and there was another one cracked too! I need replacement parts and to make you all aware of this danger.
