Question about Samsung SCX-4100 All-In-One Laser Printer
Add paper I have paper in there and the reader says "Add paper/ No Paper".It won't let me print even when there is paper in the machine.
  • 3 more comments
  • Anonymous Dec 20, 2007
    the printer tells me to add paper/no paper even though there is paper in there.
    Same.. worked flawlessly for years, now it says no paper, add paper. I've taken out the tray multiple times, tried different paper, restarted.. same thing
  • edmclgg Jan 31, 2008
    I have the same problem where it is telling me [No paper] Add Paper, even though there is paper in there. I have taken the paper tray in and out multiple times. I also went to Start/AllPrograms/Samsung SCX-4100 Series, clicked on Maintenance icon, and ran that. I successfully printed the test page. Thought it was fixed, so tried to print my document again, and got the same error of [No paper] Add Paper.
  • raanaz Jun 04, 2008
    i have the same problem and i tried all the suggestions nothing worked. somebody has another solution?
  • bjbirtch Aug 07, 2008
    my scx 4100 all in one laser printer keeps giving 'no paper' message. I have added/subtracted/changed paper, unplugged the printer, added new driver. Nothing works (actually it did correct itself very temporarily and then resumed with the error message above. Going nuts!
I posted the same problem in here on 31 January 2008 and have found a solution to my problem. In the Properties window of my SCX-4100 printer, under Paper tab, I found it was showing my paper source as "Manual Feed". This was an absolute mystery as I've never used the Manual Feed, so it has glitched to that setting of its own accord. The printer would not work in any programs so it must have set itself to "Manual Feed" as the default. Once I set it back to "AutoSelect", it works fine again.
(As an aside, I discovered the answer when I was trying to print a document in Word for the nth time, and kept getting the Add paper/No Paper message. In Word, I went into File=Print= and under the Properties button opposite my printer, under Paper tab, I saw the problem. And so ended my days of frustration.)
I wish everybody else luck, and hope my post will help someone.
Posted on Feb 05, 2008
Mine does the same thing. Very frusterating! Only fix is to turn off and back on.
Even though cassette is loaded it keeps saying "add paper in cassette" and will not print
theres a sensor where the casset meets the back of the machine if it dosnt get triggered it wont see any you can trick it and it will always see paper just keep it stocked of paper
May 30, 2014 | Kyocera FS-2000D Laser Printer
Ibico 1232 adding machine won't print totals
For mine to print I have to hit either the subtotal key, or the total key. (# and/or * )
Jun 05, 2013 | Universal Office Adding Machine/Calculator...
My verifone vx510 won't print
Receipt Feeds,
But Nothing Is
Printed On It Not using thermal paper. Ensure thermal paper is being used. Thermal paper loaded upside down. Ensure thermal paper is being fed from underneath the roll, as it will only print on one side of the paper.
Aug 05, 2012 | VeriFone (M19755014US1) Magnetic Card...
Paper won't come out paper light blinks
I have a similar printer. Sometimes the bottom paper tray gets stuck or caught. Make sure the printer is on a flat surface.
1. Turn off the printer.
2. Pull the paper tray all the way out.
3. Take out all the paper and then place the tray back in.
4. Turn the machine on and let it try to print without paper.
5. When the light comes on add paper hit the button and you should be good to go.
Jul 26, 2011 | Brother HL 2140 Laser Printer
The machine won't print. It won't feed paper, The
Your machine needs to be serviced.
replace the cartridge with the original one.
it can not print if one cartridge is missing or not original.
Jul 12, 2011 | Canon Office Equipment & Supplies
The "add paper light" is on even though the paper
The light means that the printer is out of media, or the media did not feed properly
What you can do
-Load media into tray and press Continue button to resume printing.
-Check that the media is loaded correctly in tray
-Press Cancel button to cancel the print job.
Jun 29, 2011 | Lexmark E232 Laser Printer
Printer will not print, says that there is a paper jam but there is no paper in the print, and when we add paper the printer won't take it and the power light is blinking
you need to remove the black plastic on the back wipe the rollers that feed the paper put it back together plug it back in switch on and it should work some times u get a small corner of paper stuck so it tells the machine that u have a papaer jam
May 25, 2011 | Lexmark X1270 All-In-One InkJet Printer
Did something???? How do I cancel printing? Unplugging, Info I've been given will not stop printing, even when I press Delete or Cancel. It just wants to keep printing...
there is worm virus that will make a printer print until it runs out of paper and if you add more paper it will keep printing till it runs out again i would take the paper out of the machine and run an antivirus scan on your computer usually the print is not legible with this virus
Oct 04, 2009 | Office Equipment & Supplies
"add paper" cannot be cleared
may be problem with the paper roller or the paper sensor check it
Jan 11, 2009 | Dell 942 All-In-One InkJet Printer
Samsung SCX-4100 All-In-One Laser Printer Logo
159 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
