Question about Hotpoint Washing Machines
Hotpoint ARXXF109S code error F10 - Hotpoint Washing Machines
SOURCE:
SOURCE: ctd80 hotpoint dryer error code f10
If you remove the back cover of the drier with the appliance un pluged, you will see the heater bracket.
un screw this from the back panel, and at the top you will see three thermostats. There is a brown one with a small hole in the middle, if you use a pin and press in, you should hear a click. This resets the thermostat and you should be able to use the drier again.
Apparently a common fault on these indicit based driers.
it worked on mine
Posted on Oct 28, 2007
murdozzz2
  • 75 Answers
SOURCE: Hotpoint Ultima W860
hi there f10 fault code means pressure switch not sensing,
this could be to do with low water pressure or a bad connection on the pressure switch or control module which is located at the back left hand corner of the machine, remove backplate to gain access and remake all connections on module, if this should not resolve the fault i would be looking to replace the pressure first part no= C00112659 cost about £15
ps. always disconnect from mains before carrying out any work
Posted on Dec 08, 2007
Malcg
  • 32 Answers
SOURCE: hotpoint wt960
Full manual can be downloaded from this link
http://imagebank.indesitcompany.co.uk/brochures_online/pdf/Hotpoint/Laundry/ultima-7kg-lcd-wm-19505771900.pdf
Technical helpline will be able to tell you what F10 means
Posted on Apr 13, 2008
barkencoa
  • 3463 Answers
SOURCE: hotpoint ctd 80
The error code F10 is common of heater open circuit or one shot thermostat open circuit.
F8 is indicating static heater relay contact welded closed.
You need to call an engineer.
Posted on Jan 04, 2009
SOURCE: F10 error code on Hotpoint ctd80. How do I fix ? Thanks
remove 2nd largest panel on back of dryer then remove the heater unit (two small screws) from inside panel,on the top of this you will see two small units with wires going in and out both sides looking closer one of these units has a small hole using a pin push it down into hole this resets thermal cut out,you should hear a small click.
Posted on Aug 22, 2009
My dishwasher is just flashing F10 all the time
Codes are pretty generic between Hotpoint, Hoover and Whirlpool.
Heating element fault
Issue: The LED lights on your dishwasher are displaying in the following sequence (please see below these error codes for your LED reference
  • LED 1: OFF
  • LED 2: ON
  • LED 3: OFF
  • LED 4: ON
Action: We recommend you call our customer service centre to book an engineer.
Here is the Hoover site.
http://service.hoover.co.uk/advice-centre/dishwashers/
Error codes Hotpoint
Jun 19, 2016 | Hoover 24 in. HD97E Free-standing...
Alarm F10 is displyed , my washer/dryer doesnt
Hotpoint error code F10 is
"No cold fill. Check that the taps are on or if the drain hoses are kinked".
Has someone turned off the water supply or the isolator valve on the plumbing?
If not, you may have a faulty inlet valve on the machine.
Please drop a comment back on this thread if you require further help or guidance
Jul 21, 2011 | Hotpoint Washing Machines
It keeps flashing f10 and now started to flash f8 aswell what dose this mean and how do i sort it ?
Could you please tell what kind of dryer it is.Else here is a link that has all hotpoint error codes.Choose your model from the list and the error and post your comments so that i can further guide you to eliminate the error.
click here for hotpoint error codes
Please do rate my solution.Good luck with the machine.
Apr 11, 2009 | Hotpoint Dryers
Feb 02, 2009 | Hotpoint TDL15 Electric Dryer
Wf840 f10 error code get worse
F10 is indicating 2 possible probs with your m/c.
1-interrmittent cold water supply, check pressure and hose.
2-water level switch not sensing correctly, possibly sticking or partially blocked.
Hotpoint recommend calling an engineer for a pressure switch prob. but there callout is £90.00!!!!!.
Plz rate my solution.
.Thanks
Dec 31, 2008 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint ctd 80
Oct 20, 2008 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint error f10 on model wt740
F10 us usually a stuck key on the keypad. Turn the power off to the machine or kick the breaker off, press each button a number of times to make sure they are not sticking. If you find one sticking try to pop it out. Turn the power back on and try to use it. If the f-10 code returns you will need a new touchpad. Good luck to you and I hope this helped you. Mike Anderson
May 08, 2008 | Hotpoint Aquarius WF000 Front Load Washer
Hotpoint wt960
Apr 04, 2008 | Hotpoint Ultima WF860 Front Load Washer
Washing Machines Logo
79 people viewed this question
Top Hotpoint Washing Machines Experts
vince
gbob59
James Hehling
James Hehling
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
