If I ghost another drive to this one(250g) from a raid drive it will not boot in std ide slot. if I ghost it from an ide to raid slot it still won't boot in ide slot. If I ghost from primary ide to secondary ide it will not boot in ide It will boot perfectly in a raid slot what gives.
SOURCE: Hard disk not detected
The problem is that u have done partitions for 160 GB harddisk, so do all the partitions of 40 GB or less than that.
SOURCE: how to format IDE hard drive?
This drive is an IDE drive. The jumpers can be set on it to make it a slave.
Once set as a slave, you can identify the drive letter given to this drive and format it either at a command prompt: C:> format [drive:] /s (to make it bootable) or no /s to just format it.- OR within Windows: right click on the drive letter and select format.
SOURCE: my seagate barracuda 7200.7 st380011A 80gb
i think you must place a jumper on the back side of the hdd.
If there isn't any jumper, it is a "slave".
When you place a jumper on the correct spot, the hard drive will become the master hdd. The position of the jumper can be found on the hdd itself.
Search for "master" and put the jumper there
SOURCE: my seagate barracuda 7200 80
try replacing all the leads that attach to your hard drive including electrical extensions + IDE,SATA and the ones that attach from your motherboard to hard drive
have secure connections and are not faulty or just replace them they are probably old and faulty ?
good luck
SOURCE: i`m unable to install windows
How do you format a hard drive that has Windows Vista on it? I cannot find MS Dos. Thanks, Sherry ([email protected]).
