Question about Compaq Presario 5000 PC Desktop
Computer won't turn on
When i hit the on switch my computer won't respond at all. i can hear the
electricity getting to the power source - box but nothing will turn on.
    Master:
    Sergeant:
  • 482 Answers
Ether the power box went out, or the motherboard has went out on you.
Posted on Nov 26, 2007
I have a 1977 Suzuki GS400X, I get power to all
you may have a bad flasher needing replacement. just because you hear it click when you turn on the signals does not mean the bi-metallic strip inside is working.
Sep 21, 2014 | Cars & Trucks
When i turn on my Dell Inspiron 2400 Desktop Computer why won`t it start.
Is the computer plugged in to a known good power source with a known good power cord? Also, make sure the power is fully seated on both ends. When you press the power button are you getting any indicator lights? The power button itself has an LED that will be either solid green, blinking green, solid amber, blinking amber, or off. Do you hear any beeps?
May 19, 2014 | Dell Inspiron 530s Desktop Computer...
Power
Set the harmony remote to switch the pioneer first, then the rest of your stuff.
Feb 06, 2014 | Pioneer VSX1020K Receiver
Power flashes on for a second and then turns off completely
The most likely problem is that the power supply has failed.
Jul 19, 2013 | Shuttle XPC SD32G2 Barebone
There was a power outrage and now my computer won't turn on?
Check the source of power to your computer. Your computer should be plugged into a protection strip. Make sure that the protection strip reset button is reset. If that is ok, check the circuit breakers in the fuse box.
Jan 29, 2013 | Computers & Internet
Start then not start,no power to inestion or starter ,then start and run a while shut it off then wont turn over again
It may be a bad ignition switch, that or a loose or bad electrical connection somewhere. Check for corroded terminals in the power distribution box near the battery. If no help, you may need an electrical diagnosis of the ignition circuit and the ignition switch.
When it won't respond, do lights and other accessories work? If no, it's a main power problem near the battery or distribution box. If yes, it sounds like the ignition switch or the wiring from the switch to the starter or to the ignition system.
Oct 23, 2012 | Chrysler Town and Country Cars & Trucks
My fog lights won't work but switch shows power, however when hit the switch can hear the relay on passenger side fuse box can hear it click does that need replaced
Hi, if the light on the switch is coming on, the relay is fine. Unless both bulbs are burned out, the problem is in the wiring between the relay and the lights. I recommend you trace the wiring backward from the passenger side fog light to the power box under the hood to see if the wire is cut. There should be two wires coming out of the power box--one going to each fog light. If the wiring looks good, it is also possible that the ground to the lights is bad.
Aug 29, 2011 | 2000 Oldsmobile Alero
Can't get to booklist won't respond to touch
Hi!
You can try hitting the reset at the bottom for 3 sec. and then slide the power switch.
If the unit gets froze you can try the following:
1. Connect the reader to the AC Adapter (If available). If not, then connect the Reader via USB to the computer
2. Hit the reset button for 3 seconds.
3. The red steady light should come on, if not, try the reset again while the unit is connected
4. Allow the reader to charge for 40 Minutes (on PC make sure the computer does not go into sleep mode.
5. Disconnect the reader and see if operational.
GoodLuck!
eBookBoy
http://digialreader.freeforums.org/
Aug 04, 2011 | Sony Reader Touch PRS-600
My dodge dakota truck will not start. It has power we tried to pop the clutch too.
do you mean the truck won`t start and run or do you mean it won`t turn over with the key.if it won`t turn over with the key the you may have a starter problem.if you mean won`t start then it could be the fuel pump not working.with someone cranking the motor you should hear the fuel pump running with the gas cap off and listening at the filler neck.or hear it running listening under the truck at the gas tank.if you don`t hear it then you can hit the tack sharply with your hand or a rubber hammer,it hear the pump start to run then the fuel pump needs replacing.if not check the fuses under the dash and under the hood.if they are good then it may be the pump relay in the relay box under the hood and it should be marked on the box or lid.
Apr 16, 2011 | 2000 Dodge Dakota Quad Cab
Compaq Presario 5000 PC Desktop Logo
112 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Lee Durbin
Lee Durbin
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
