Question about Samsung LN-S4695D 46 in. LCD HDTV
Samsung LN-S4695D 1080P LCD TV - 1 year old
I have two defined horizontal bars separated by about 12" of faint ghosting that rolls from bottom to top of my 46" screen. It is more apparent at times than others. But it's there. It's been seen by my cable provider, Cox. They've checked signal strength and it's A-okay. It's not always there, but I'd say about 60-70% of hi-def viewing. A salesperson at Best Buy called it a 60 cycle hum. I've been told it may be the power supply. Either the filter capacitors or the rectifiers have taken a dump. What do you think the problem is. I've got the extended warranty program.
    Brigadier General:
  • 6,966 Answers
Re: Samsung LN-S4695D 1080P LCD TV - 1 year old
If I may add to tech8's and shivam4529's posts, pls try:
1. Removing any and all other devices (such as a DVD, etc) attached/connected to the Samsung LN-S4695D 1080P LCD TV and only leave the cable connected. This would include the audio and video cables + any other wirings as well as their plugs to the mains. So in effect it would only be the TV and cable. Power up the TV and observe if the horizontal bars appears again. If no, please proceed to Step 2, if yes, please proceed to Step 3;
2. Plug in your other devices one at a time and determine at which point/device the fault appears. In so doing you will be able to single out what device is causing the horizontal bars;
3. If it is just the cable and the TV and you still have the fault, get hold/borrow an old VCR plus a known good clear VHS tape. Remove the cable connection. Hook up the VCR to the TV using the RF OUT of the VCR to the RF/ANT/Cable IN of the TV. Do not use the video/audio connections. Power both TV and VCR and insert/play the tape. On the TV, select either Channel 3 or 4 whichever will display the tape movie. Observe if the fault appears again. If not, please see 4, if yes please see 5;
4. Something is wrong with your cable. The signal strength might be strong/OK but it is dirty/noisy and that is where the 60cycle AC hum is riding in to your TV;
5. Then you need to make use of the extended warrant and claim/demand service. Be it the capacitor, rectifier(s) or the entire power supply, the unit would require service. Allowing somebody else other than their authorized service personnel to work on your unit would probably void your warranty.
Hope that this be of additional help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Posted on Nov 26, 2007
    Uploaded 5 video answers.
  • 150 Answers
Try this will help u when my tv shows the problem i refer to this site only
  • 298 Answers
1.A change in capacitance ot the main filter
capacitor is the usual suspect
2..bridge rectifier
3.ground loop in cabling system or house
ground or changed capacitance of filter capacitor
in vertical output citcuit (lighter bars)
0 characters
3 Points
LN-S4695D replacement stand
do you by chance have a pic of your old broken neck? I have a few Samsung pedestals in stock.
Dec 01, 2012 | Samsung LN-S4695D 46 in. LCD HDTV
Have a Samsung LNS4695 DX LCD about 3 1/2 years old. When powers on will take about 5 secs and then picture but has thin, multicolored vertical lines. After turning off and on a few times, picture is...
yes this is due to bad caps I have replace dozens of caps for samsung tv's you can do it your self or have some body do it for you or ship the power board to me
Sep 04, 2010 | Samsung LN-S4695D 46 in. LCD HDTV
Extra port door cover
It is an extra bottom cover if ever the one in your TV is accidentally broken. You can replace it with that part.
Jul 03, 2009 | Samsung LN-S4695D 46 in. LCD HDTV
Faint Vertical lines on Samsung LCD TV
Your correct, LCD's don't burn. This sounds like a defective main control module. I would take it in as soon as possible to have it looked at.
May 03, 2009 | Samsung LN-S3251D 32 in. LCD HDTV
Broken Screen
Replacement LCD panel is on Ebay.
Jun 28, 2008 | Samsung LN-S4695D 46 in. LCD HDTV
Horizontal bar of green tint the moves from bottom to top of screen
This may be a power supply fault, and what you are probably seeing is some switching noise breaking in through the display processor, or possibly the input processor. Because of the fact that the bar is moving, this means that the sequence is not locked to the main processors.
You should contact the place where you bought the set and speak to someone about an exchange. A one day old set should be exchanged right away, and I would argue that fact.
I don't want to mention any name brands, but I would have gone for a company that also manufactures TV broadcast and industrial TV equipment rather than one that manufactures appliances.
Jerry G.
Jan 29, 2008 | Samsung LN-T4665F 46 in. LCD Television
Noise and horizontal line
Very easy Fix, The problem is the cable box is not grounded properly. (not your fault) Go to the Local store and get a Plug adapter, just to change the TV plug that goes into the wall or surge protector from 3 to 2. Trust me on this....
Best regards
Nov 29, 2007 | Samsung LN-R328W 32 in. HD-Ready LCD...
Samsung LN-S4695D 46 in. LCD HDTV Logo
298 people viewed this question
Top Samsung Flat Panel Televisions Experts
xxxxxx xxx
Steve McIntosh
Level 1 Expert
Steven Wander
Steven Wander
Are you a Samsung Flat Panel Television Expert? Answer questions, earn points and help others
