Question about Pentax Cameras
Pentax water pump not shutting off - Pentax Cameras
Where can i get a manual forthe pentax water pump cam 50
Although it has a manufacturer's name of Pentax, I don't think this is a camera. Industrial Machinery may be a better option.
May 06, 2017 | Pentax Cameras
Pentax smart head
Check the pressure switch. Be sure you have enough water available. Check for a leak. What are you pumping. Is it pumping. I am not familiar with this pump so I am just listing some points to check. If it is a submersible well pump it can develop a lot of pressure.
Nov 29, 2013 | Plumbing
What causes a pentax smart head to cut off and on during use of water
There's not enough water running into the pump this is why its cutting out , hope this helps
Oct 09, 2013 | Plumbing
Pentax water pump
A few more details would help such as model number, is it plugged in etc.
Aug 03, 2013 | Plumbing
Pentax Cam 100 pump blowing capacitors. Fitted new motor as the old pump did the same
Are you sure the rotor on the motor is rotating freely and getting up to full speed? Did you try running the motor without attaching the housing that actually pumps the water?
Jan 17, 2018 | Pool & Spa
Pentax water pump 1/2 hp when pump starts works well but pump does not cut out when all taps in the house are closed
it sounds like the switch is faulty take it back to the shop and tell them ok
Mar 28, 2011 | Vacuums
Pentax e10 shuts off The pentax optio e10
You probably set the auto power-off for energy saving
Jul 12, 2009 | Pentax Optio E10 Digital Camera
Cameras Logo
105 people viewed this question
Top Pentax Cameras Experts
Ekse
Jerry Greenberg
Jerry Greenberg
FIKRET UNALIR
FIKRET UNALIR
Level 1 Expert
Are you a Pentax Camera Expert? Answer questions, earn points and help others
