Question about Toshiba Computers & Internet
Toshiba Satellite laptop screen flickering
Screen flickering for couple of weeks.
    Top Expert:
  • Toshiba Master
  • 85,108 Answers
The screen is failing.
Posted on Nov 03, 2018
SOURCE:
  • 31 Answers
SOURCE: Screen flickers
yes i have had this problem before
the propper signal isnt getting to the screen from the mother board
has anything been spilt on the screen or the computer its self
i would suggest taking it to a tech they should be able to fix your problems
Posted on Jul 19, 2008
rockitman187
  • 2559 Answers
SOURCE: Screen stays black
Startup while tapping the F8 key,this should open the startup options screen,Select start up in VGA mode,If that works,then you need to update the video drivers
Posted on Jan 07, 2009
  • 700 Answers
SOURCE: toshiba laptop screen dicstorted
Loose electrical connection or its loosing its grip to hold your screen. If you can do it on warranty then try. Or have it check by a technician.
Posted on Apr 07, 2009
Geekman
  • 32281 Answers
SOURCE: Friend's Laptop Screen has become too dark to work with
You could have a defective screen - a defective inverter or a CCFL lamp.
To determine if you have a LCD screen or video card problem, read this and follow the instructions.
Defective CCFL backlight, it may have the following symptom:
  • Screen flashs on red/pink and off.
  • Picture stays on in red and slowly be come normal.
  • Picture flickering with dim display.
  • Picture flickering on and off.
All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp
Connect an external monitor to your laptop and power it up, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight.
Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out www.lcdparts.net for parts, repair service and DIY info.
Posted on Apr 24, 2009
ruben_barrer
  • 117 Answers
SOURCE: Toshiba Satellite laptop w/ blank, black screen & blinking cursor
the hard drive is not checking in correctly. go into your f2 function which is your bios. see if in there during the boot options if you have a hard drive showing up. if you do, you would need to check if the hard drive has failed or the o.s. is corrupt.if you do not see a drive there, its failed, check to see if its seated correctly. if it is seated correctly the drive has failed and will need to be replaced.
if it shows up, and if you have your restore disk, load it and select repair. it will look for the hard drive and any windows installations. if it does not find any. then the drive is bad and will need to be replaced, in the event it does find the windows installation then continue to repair the machine software.
Let me know what happens when you try this
Good Luck!
Ruben
Posted on Jul 23, 2009
Screen flickering
I've had a couple of problems with mine, what it usually is is the wires coming loose, I've also had to replace the screen.
May 20, 2012 | Toshiba Satellite L505-S5966 Notebook
Flickering screen Toshiba P105
Flickering, always cause by LCD cable. Change it at any computer shop or service center and its not so expensive
May 08, 2010 | Toshiba Satellite P105-S6104 Notebook
Toshiba L300 screen flickers and backlight
Maybe is the backlight power cable cut. Try with the laptop in power on mode oppening VERY SLOWLY the screen to see if at a certain potition it works fine. Open it all the way up sometimes to check it. If thre is a potition that it works, it's the cable as I mentioned.
Stelios
Feb 20, 2010 | Toshiba Satellite Pro L300 Notebook
Screen Flickers
Sounds like your screen is failing. Could be just a loose connector behind the screen (pressure changes the screen display), but best advice is to replace the screen.
Oct 04, 2009 | Toshiba Satellite M305D-S4829 Notebook
My new Satellite M305-S4910 is experiencing a monitor flickering. What can I do to stop it flickering?
Remove the power strip above the keyboard and the keyboard and remove the bezel on the LCD. This will give you a clear view of the wiring leading from the screen to the motherboard. Look for a loose connection or rubbed or frayed wiring. Also, a lot of video problems are from the cable getting loose that runs from the back of the screen. This is a flat cable the fits in a socket on the back of the screen.
Here is the lcd removal duide for your laptop....
http://www.irisvista.com/tech/laptops/Toshiba-Satellite-M305/remove-screen-inverter-video-cable-1.htm
Sep 22, 2009 | Toshiba Satellite M305-S4826 Laptop
Screen flickers and dies
You have a faulty LCD inverter board.. Go here for instructions on how to replace and find a new one, or you can search on ebay for one. http://www.irisvista.com/tech/laptops/Toshiba-Satellite-A105/remove-replace-LCD-screen-1.htm
Sep 11, 2009 | Toshiba Satellite A105 Notebook
Flickering Screen on Model P105 Toshiba Satellite
on the back of the LCD is a cable that goes from there to the Motherboard. Try reseating that cable on both ends. If that doesn't fix it then it has to be a problem with either the screen or the cable behind the screen.
Aug 11, 2009 | Toshiba Satellite A105 Notebook
Screen stays black
Jan 07, 2009 | Toshiba Satellite L305D-S5895 Notebook
Computer screen is upside down
u need to open the monitor control menu by pressing the menu key on the monitor then select the option showing two bent arrows one facing up and the other down, then adjust.
Mar 14, 2008 | Toshiba Satellite A205-S4617 Notebook
Screen Flickers on and off
If you see picture but kind of dark it may be cable that powers back light.
Jan 31, 2008 | Toshiba Satellite 1805-S253 Notebook
Open Questions:
Computers & Internet Logo
69 people viewed this question
Top Toshiba Computers & Internet Experts
Alun Cox
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
