Question about Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC
Windows Vista problem
Just connected plug and play Norcent LT 2020 monitor to my HP Pavillion
s7700n PC. No sound coming though I have green line connected to PC and Monitor. Monitor installed as generic. Video working fine. All PC troubleshooting says sound drivers working????
    Problem Solver:
  • 13 Answers
Re: Windows Vista problem
Thre is option in control panel sound to choose out put sound in windows vista like 4 in 1 speaker, laptop speaker etc. try that also or u r talking about speaker with monitour or externer speakers. this blog is about windows vista helps and many windows vista tips for troubleshooting -
Posted on Apr 19, 2008
I recieve messages from my notebook window vista problem but i dont known how solve thisproblem.
Posted on Jan 01, 2008
  • 482 Answers
You need to download the driver, go to the web site and find the download
Posted on Nov 26, 2007
0 characters
3 Points
Why has my windows vista home premium system suddenly stopped the sound coming through when I want to play music from napster site through my pc? I have the pc connected to 2 speakerS.
this could be an issue with driver or service failure in the computer..
try restarting the computer in safe mode .. and see if the internal speakers work.. try running a driver update through device manger.. check the cables of course.
if that does not help .. then call 1-877-805-1027 for expert help
Jul 23, 2015 | Microsoft Windows Vista Home Premium...
I have a HP Pavillion dv6000. I cant seem to play blu ray dvds on my laptop, even though it says blu ray disc on there. Can you help with this please??
Windows Media Player does not play Blu Ray discs. You need 3rd party software such Cyberlink Power DVD. Follow that link and you can download a 30 day trial.
Mar 23, 2011 | Operating Systems
When ever i my computer goes to sleep the monitor wont come back on. If i turn the monitor off then on the screen comes on for about 2 seconds then is black. The only way to get it to come on and stay on...
Control panel > Power options > Choose power plan> set to Never turn off display / Never put monitor to sleep
(For Vista... XP similar) Not sure about Win 7, will not be much different
DVD Issues, possibly the media being used, only real way is to try another DVD drive in the tower
Jan 06, 2011 | Operating Systems
No sound and video
Video issue:-
Assuming the system power comes up, does the monitor power come on? Most monitors have a status LED on the front bezel that should show green, orange, or blinking if the monitor is powered on. You can hear CRT monitors power on with a gentle sound, though I can't describe it beyond saying it's the sound of a CRT tube warming up. Make sure the monitor is plugged into a good outlet by testing the outlet with a lamp or any other device that will prove beyond a doubt that the outlet is good. Make sure that the power cord is either permanently attached at the monitor end or that it is seated fully in the socket, since partial cord insertion is the most common failure for monitors with detachable cords.
LCD displays don't make any sound when you turn them on, but they don't have a simple power cord, either. Older LCD monitors are usually powered by an external transformer, which in turn is powered from a regular AC outlet. If the LCD display doesn't show any signs of life, make sure that the cords into and out of the transformer are fully seated. Some transformers are equipped with a status LED to show when they are operating. The power connection to the LCD display is often awkward to inspect, recessed into the back of the display. The important thing is to make sure it is started correctly, then seated all the way.
Sound issue:-
No Sound From all speakers
  • Check that the speakers are powered on.
  • Check that the speakers are connected to the correct ports on the PC. This is particularly important If the customer has both integrated sound and a sound card.
  • If the speakers have a volume control button - ensure that this is turned up.
  • Check that the Windows Audio service is running. If this is not running then many of the subsequent troubleshooting steps will not work. Go to Start->Run and type services.msc. Double cliick on Windows Audio. Select Start if possible and check that the Startup Type is Automatic. Click OK.
  • If the speakers are digital speakers then try forcing the sound card to use digital. Go to Start->Control Panel->Sound and Audio Devices.. On the Volume tab, click the Advanced button in the Device Volume section. In the Volume Control window, below the Play Control Volume slider, click Advanced. If this does not show select Advanced Controls from the Options menu. Select Digital Output Only
  • If possible try an external audio source like a Walkman, CD, or MP3 player (connect the speakers to the headphone jack)
  • Check that the volume control in Windows isn't muted or turned too low. See the screen shots below. Go to Start->Control Panel and double click on Sounds and Audio Devices.
Aug 06, 2010 | Operating Systems
Everything is green the screen the pictuers the letters etc.what`s wrong i have a windows vista /acer
If you have a desktop computer, try connecting a different monitor, to see if your monitor is not producing all three "primary" colours (Red/Green/Blue), thus resulting in "mostly-green" colouring.
If you have a laptop-computer, trying connecting an external monitor, to see if you get the correct colours on the external monitor.
May 17, 2010 | Microsoft Windows Vista Home Basic Edition...
Cannot Head Mic-In Audio
You can use the mic in like a line in just have to turn the volume up on the source or use a program to amplify the data in post processing
Jun 29, 2008 | Microsoft Windows Vista Home Premium with...
Help me plz
i hv purchsed HP Pavilion tx1000 notebook pc. it was getinig vy heat due to this region pc was getting shut down. i hv given it to my near by service center. but still it is not working properly. its web cam as (HP pavilion Webcam Driver for Vista v061.001.0005- chicony) driver is also not loaded properly. when opens with net it gives error.
pls help me wht to do?
Apr 10, 2008 | Microsoft Windows Vista Ultimate Edition
Connection to internet-vista program on laptop-use cellphone as modem
use nokia pc suite
get the right settings on your phone
there is no prob with vista as far as i know
pair the phone and comp properly via bluetooth or USB
and i think youll have a good connection
have a good day
Mar 26, 2008 | Microsoft Windows Vista Ultimate Edition
Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC Logo
102 people viewed this question
Top Microsoft Operating Systems Experts
Brian Sullivan
Brian Sullivan
Scott Fryer
Alex Krenvalk
Are you a Microsoft Operating System Expert? Answer questions, earn points and help others
