Question about Action Office Equipment & Supplies
BIANCO PUMPZ -MODEL BIA-TECH40PC POWER IS OK. PUMP LIGHT FAILURE ON. RESET BUTTON NO ACTION
    Dedicated:
    Visited the website for 20 consecutive days.
  • 439 Answers
I have worked on these pumps. More than likely the front bearing has seized. Unfortunately these pump motors appear to be a relatively low quality unit. You can try to disassemble the pump impellor housing and attempt to turn the pump manually. If the pump bearings haven't frozen up completely you may get some limited life out of it. It is not an easy task to completely strip the pump motors as the die-cast metal housings are prone to corrosion and have a tendency to crack or crumble especially if the bearings have rusted into the housings. If the pump motor has failed, salvage the pump controller pressure switch from it and fit it to a replacement pump. Look on ebay for something similar like a QB60 peripheral pump. They are quite cheap but quality varies depending on the vendor/supplier.
Posted on Nov 02, 2018
2 Suggested Answers
  • 78 Answers
SOURCE: Forgot my username cant log into laptop, help
Posted on Sep 22, 2014
  • 6277 Answers
SOURCE: pump not starting automaticaly.
Sorry but I do not know your particular machine BUT I would suggest as a first step that you clean the drain motor lint tray/filter. So many 'faults' are caused by blocked filters. The motor is unable to drain all of the water in the allotted time.
If you are unsure where the filter is, it is normally behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and held in by a round cover/knob.
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT!
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. If it doesn't work then the motor is malfunctioning!
Hope the filter is the problem and good luck!
John C
Posted on Feb 19, 2011
Canon Pixma MG6650 waste ink absorber full
hi, you have to remove/or replace the ink absorber pads, or perhaps wash them out. the printer then needs a reset.ie hold in power button to turn off, then hold in power button and keep holding in until printer starts and then turns off. that should reset it(clear any registered faults). it should now start ok.
Nov 09, 2017 | Canon Office Equipment & Supplies
Where is the reset button for the fuel pump
Only Fords have them. Check for power on the fuel pump wire at the gas tank connector with the engine being cranked over. If power there, and no pump action, the pump has failed. If no power, find and check the fuel pump relay - under the hood in the fuse/relay block. First, see if the power feed to the relay is good. One of the terminals that the relay plugs into will have a "hot at all times" power signal. Use a grounded test light, key off, and probe all the terminals-one should show power-will light up the test light.
Post back for more help. Good luck.
Apr 18, 2014 | 1995 Oldsmobile 88
Fisher and paykel GW509 won't power up, pump not blocked, plug loose?
62. (00111110) Phase 5 - Pump Over Current
The Motor Controller module has detected an excessive pump current.
Primary Source: Pump.
Action:
Replace Pump.
Secondary Source: Motor Controller module.
Action:
Replace Motor Controller module.
107. (01101011) Phase 2 to 6 - Motor Controller module Reset Error
The Display Module has detected that the Motor Controller module has reset when
it should not have. This can be due to a Motor Controller module supply
disturbance or microprocessor failure.
Primary source: Motor Controller module.
Action: Replace Motor Controller module.
Red, Blue, Yellow go on the motor
Brown , White go on the pump.
Apr 13, 2012 | Fisher and Paykel Fisher & Paykel Washer
Pump not starting automaticaly. green power light on, red failure light on . usually if pump stops,i just press reset. bianco 60 water pump
John C
Feb 19, 2011 | Washing Machines
ALARM light is on, and not able to print I already
Try this reset on the printer
  1. Start with printer off
  2. Press and hold resume Button (triangle in the circle) and click "Power" button. green led should be on
  3. hold the Power button, release Resume Button.
  4. Without releasing the Power Button, double click "Resume" button and then release Both Buttons.
  5. Click "Resume" for four times then click "Power" button, to confirm the selected action (reset counter absorber).
  6. Turn off the printer and turn on again
* Please rate this solution with Thumbs up and comment to help us improve providing support
Dec 01, 2010 | Canon PIXMA MP210 Photo All-In-One Printer
Error : Oxc 18a0206
here.. check this out. a solution to your problem.
These are reset instructions designed to clear most of hp errors starting with 0xc...It works on different hp models.. it could work on you too.
Semi reset
1. While your printer is on.. unplug to power cable from the printer.
2. Press and hold the "OK" and "HELP" buttons while you plug the power cable at the back of the printer. Try these steps to reset your printer to default setting.
Full reset
1. Press & hold " * " key...(asterisk sign)
2. While holding the " * ", press "#" key and then release both keys..."Enter Special Key Combo" will be displayed...
3. Press "1", "2" and "3" to display Support...
4 Press ">" right arrow button and release when System Config Menu appear....then click OK
5. Press arrow key to display Hardware Failure Status...click OK....
6. When Hardware Failure Status:Clear appeared, press "OK" to clear...
7. Press "OK" again to display "Hardware Failure Status Cleared. Press Cancel To Continue".....
8. Press "CANCEL" as many times to display "Welcome To Photosmart Express" or "Ink System Failure".....
9. The last part is to turn off the printer and unplug at the back...wait for 30 sec, then plug and turn on the printer...if asked, press "OK" to continue and allow the "One Time Ink Initialization" to proceed..After this try to print...
If you find the reset solutions helpful...Please rate this solution and vote YES ..thanks..
Jul 30, 2010 | HP Photosmart 3210 Printer
Wont restore to factory default
Reset the settings of the user mode (except
user codes and related counters).
[0 = No / 1 = Yes] This is equivalent to a system reset
performed by user programs.
enter SP mode
Yellow key, 1 0 7 Red button for 3 seconds.
After selecting "1" hold type
Original and press the OK button (or) to reset.
If the reset is successful appears
the inscription, "Action Completed". Failure to do
display "Error!"
Jul 22, 2010 | Ricoh Aficio 1013F Copier
Failure to print
Please follow the below steps.
STEP 1.
Please take out all the cartridges and clean the copper contacts with the help of a lint free cloth and the water.
STEP 2.
1. Un plug the power chord from the back of the printer.
2. Press and hold the power button of the printer.Wait for 30 seconds.
3. While holding the power button, re-plug the power cable.
4. Turn on the printer, if it is not on.
STEP 3.
Reset the All-in-One to the factory default settings by using these instructions:
1) Press Red Eye Removal & Print Photos button simultaneously
2)Enter Special Key Combo is displayed on the screen.
Press and release in sequence "Red Eye Removal", "Print Photos", "Red Eye Removal"
Display should say "Support" and display the FW rev XXXXX.
3) Press Right Arrow button untill "Reset Menu" is displayed. Press OK.
4) Press Right arrow untill "Semifull Reset" is displayed.
5) Press OK.
Arter all these steps, if the issue still persists, please follow the below steps.
A. - Press and hold the “*” key.
B. - Press the “#” key and release both keys.
Display should say “Enter Special Key Combo”
C. - Press and release in sequence the “1”, “2” and “3” buttons.
Display should say “Support” and display the FW rev (something like R0631R)
Press and release the right arrow button until the display says “System Configuration Menu”.
1. Press and release the “OK” button.
2. Display should say “Hardware failure status”. If not there already, Arrow Key over to “Hardware failure status”,
3. Press and release the “OK” button.
4. Display should say “Hardware failure status: Clear. Press OK to clear”.
5. Press and release the “OK” Button. Message changes to “Hardware failure status Cleared. Press Cancel to continue”.
6. Press and release the “CANCEL” button as many times as necessary, so that, either the “Welcome to Photosmart Express” screen appears, or, the “Ink System Failure” screen appears. PLEASE DO NOT TRY TO PRINT AT THIS STAGE.
7. Using the Power Button, turn the unit OFF and unplug the power cable from back of the printer and wall outlet.
8. Wait 30 seconds for the power to get discharged and then plug the power cable into the wall outlet first and then into the back of the printer
9. Turn the unit on. The printer may display message “USE POWER BUTTON TO SHUTDOWN THE PRINTER” followed by “PRESS OK TO CONTINUE”. Press OK.
Apr 18, 2010 | HP Photosmart C6100 All-In-One Printer
Ink absorber is full canon MP145
Hi this works with some MP printer gave it a go.
First you must Turn off the printer
  1. Hold the Resume Button (red circle in the triangle), add a printer (click "Power") an indicator light green.
  2. Hold the Power Button, release the Resume Button.
  3. Not releasing the Power Button, double click "Resume" and release Both Buttons.
  4. Click "Resume" for Four times
  5. Once you click "Power", to confirm the selected action (reset counter absorber). To disable the printer "Power" button to click again.
Dec 14, 2009 | Canon PIXMA MP150 All-In-One InkJet...
Underneath Light funtion stopped working on Kenmore 62642 model
We see this a lot. The problem is on the control panel, which we regularly repair nationwide for $39.95 postpaid.
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
Details of our service and critical safety information and disassembly information is at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
We're happy to help and we appreciate your thoughtful rating of our answer.
Feb 17, 2008 | Kenmore 62642 / 62644 / 62649 Microwave...
583 people viewed this question
Top Action Office Equipment & Supplies Experts
k24674
Marvin
Marvin
Are you an Action Office Equipment and Supply Expert? Answer questions, earn points and help others
