I have a GVP7811 and it will not play correctly. The best way to describe is that it has a horizontal line issue. It is not the disc because even the menu items show lines. Is there an easy fix? Is Go-Video still around?
I am looking for code to program a GO VIDEO remote to a RCA TV. The only thing on the remote is (GO VIDEO DVD video 00058E)
Posted on Apr 11, 2008
How do you hook up this dvd player to the tv. the plugs are blue green and red instead of white yellow and red
The DVD player has component video as well as the S-video and RCA video and two RCA audio outputs.
If your player is the same as my picture, the component video jacks are in a horizontal line at the top of the back of the player. The white and red audio jacks are in a vertical line to the left. The yellow video out jack is in the second line just below the component video jacks (in a line with the coax port, the S-video port is in between the coax and the RCA video out). (The white jack is at the top left of the connections block, red below that, and yellow to the right of the red.)
I hope this helps.
May 29, 2010 | RCA DRC247N DVD Player
Dvd player plays dvd but the screen only shows lines & the audio is fine.
Sounds like your av cables may need to be replaced or the DVD is bad. Check that the cables are in the correct ports coming from the DVD player to your television and that the cablesd have also been placed in the correct postitions.
Good luck
Nov 11, 2009 | Drive Mobile Entertainment MOBILE VIDEO 7...
Horizontal lines on screen.
Your unit may have a loose connection from motherboard to the display (video cable inside the unit), another distinct possibility is that the video processor chip is damaged or there is a power supply problem for the video chip (a bad electrolytic cap or similar somewhere around the video IC).
You can check the connection, but you'll need to take the unit apart, also check other connectors, but if it's an IC problem, this could get difficult or/and costly.
Please note that these are only suggestions and that the problem may as well be something else.
3rq8 (Triarcuate)
Jul 23, 2009 | Audiovox D2010 Portable DVD Player with...
I have just purchased a Toshiba Integrated Digital LCD TV and I can't seem to run my DVD and Video player through the TV. I'm probably not connecting it right, but don't know what else to try. Thanks for...
The DVD and video player have HDMI. Component, S-Video and RCA audio/video output connections that need to be connected to the appropriate inputs on your TV. You select the type of connector and cable to use.
HDMI provides the best quality, if available and works for both audio and video.
The TV's, DVD's and video player's manuals describe how in detail. Look at the connection instructions and diagrams. You then must select the correct input on the TV to play each source.
Mar 09, 2008 | Televison & Video
Video keeps flickering
Jan 30, 2008 | Farenheit DVD-36 Car DVD Player
Video Issue
It sounds like you have the "progressive scan" mode enabled. This changes the order that the scan lines (each horizontal line) is sent to your TV. When this setting doesn't match what your TV expects, you get this effect.
Apr 16, 2007 | GoVideo VR3840 DVD Recorder/VCR
DVD no video
make sure that the wires are connected properly if they are then take the set to a tech you are having a problem in your video circuit.goodluck.
Apr 01, 2007 | JVC HR-XVC33U DVD Player/VCR
DVD recorder -- displays blue horizontal lines only
Most DVD players today are very inexpensive.
If your system is working well otherwise, I suggest purchasing a new DVD player. Try that solution. If for any reason it does not work then another problem may exist which may include an issue with your TV!
May 02, 2017 | Samsung DVD-R4000 DVD Recorder
Televison & Video Logo
123 people viewed this question
Top Televison & Video Experts
