Question about Eureka Enviro Steamer 310 Stick Vacuum
Kenwood Steam mop
We bought a Kenwood steam mop with the express purpose of cleaning our ceramic tile floors in the kitchen. We were under the impression from reports we have had that the steam mop would be the most effective way of keeping this floor clean (more effective than mopping with bucket and mop, which took quite a bit of back work). However, while the steam mop makes some difference, it hasnt been as remarkable as we thought. Is there something special we need to know about how to more effectively clean these floors? They are ceramic tiles which are reasonably textured and they have grout in between which always seems to stay dirty even after mopping with the steam mop or traditional mop.
The Manufacturer suggests you clean the hose by removing the water tank dammed if u can get it off though.
Posted on Mar 26, 2011
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 14 Answers
There are also bristle brushes (usually yellow brushes with white bristles) attached to handles which help scrub grout lines. If there are areas that are especially dirty or have build-up on them, you can use a stiff nylon wire brush or fine wire brisle brush to spot scrub areas. Make sure not to continuously scrub in one spot with those type of brushes because they have the tendensy to remove grout quicky causing a recessed dip in the grout.
In the event you get the floor and grout clean, I would suggest the first thing you do next is find a high quality ceramic floor tile and grout sealer. If the floor is in an area that does not have excessive moisture you will find the floor is extremely easy to keep clean.
The main problem with sealers is if the floor has the possibility of getting and remaining wet, the floor becomes slippery. ( Such as a tiled entry or bathroom )
Good luck and I hope this helped.
Posted on Sep 30, 2009
To clean tiles & particularly the grout you need what commercial cleaners call a "doodle bug", basically it's a giant scourer pad on a mop handle. They come in different grades of scourer, depending on the floor surface. Cleaners also masking tape steel wool or scourers onto the toe of their shoe to use to remove tough grime.
Posted on Aug 31, 2009
I was given shark 2 steam mop no instructions also does it work on bath tile and kitchen floor tiles
http://www.sharkclean.com/customerSupport you can find your instruction manuals here & print them at no cost . also yes you can clean all kinds of things with those , i would even go so far as to say you can clean the walls
Oct 21, 2016 | Shark Vacuums
My h2o steam mop does not produce steam.I have only used it 6 times. I have tried using 1 part vinegar and 2 parts water to clean the system but no joy.
The H2O Mop X5 is designed to thoroughly clean floor surfaces, such as marble, ceramic, carpet, stone, linoleum, and sealed hardwood floors and parquet. Not all floor types are suitable for steam cleaning. For more details about h2o mop please visit ADS TUTORIAL
Oct 28, 2012 | Vacuums
Hazy floor
If your floor has acrylic finish then some solutions will dry coat the top. Does buffing it after litely with a rag shine back Up. If so then you need to get solution made for your floor.
Jul 29, 2012 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Using the Shark steam cleaner on floor with unsealed grout
Yeah it will work fine...
Here is a tip that I wrote about the Euro-Pro Shark Steam Mop and why it maynot be getting steam to the head...
Euro-Pro Shark Steam Mop Problem
Here also is a link to get any of the Shark Manuals that you need.
heatman101
Jul 09, 2010 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Streaking
you maust have some type of wax build up on ur porceline tiles that has not been removed, and should never been used to begin with as poceline is its own finished luster...or you may have used a strong concentration of cleaner that has left behind residue and needs more water clean up.....try looking to see what type of lines,and size the streaks are and decide if they are created by the cleaning pocess or are left behind by the cleaning solution.....good luck...hope this helps..
Feb 26, 2010 | Euro-Pro Ultra Steam SharkTM II Hard...
Have Shark steam mop...used it but my floors are sticky.. ceramic tile....not all ove...what can I do????? and can I use vinagar in it
Yes, vinegar will work...may not steam right though...
heatman101
Jan 21, 2010 | Euro-Pro Ultra Steam SharkTM II Hard...
Engonmic hand grip broke off
Check the manuals link and maybe they will replace it under warranty...
heatman101
Aug 24, 2009 | Euro-Pro Shark Steam Mop - Gray/ Purple...
I'm considering a steam mop. Do you know if they
I dont know if you are in the U.S or U.K If you are in the U.K there is a model called the Hometek Light n Easy. Its suitable for hard floor cleaning but poor on carpets. Generally most steam cleaners with carpet attachments dont do very much unless you consider premium machines such as Polti
Mar 13, 2009 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Poor cleaning
This type of problem usually is not he fault of the Shark Steam Mop.
The problem is the old residue left on the floors by other cleaners.
Here is a tip that I wrote that will help you out with that problem...
Shark Steam Pocket Mop Cleaning Problems heatman101
Oct 27, 2008 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Eureka Enviro Steamer 310 Stick Vacuum Logo
2,367 people viewed this question
Top Eureka Vacuums Experts
Jim Parker
Jim Parker
charlesjo336
Level 1 Expert
Are you an Eureka Vacuum Expert? Answer questions, earn points and help others
