Question about Refrigerators
My Brand New Fridhe is not cooling on the top. Freezer is workin. What do I press to re set?
    Top Expert:
  • Refrigerators Master
  • 6,066 Answers
Maybe dampervis shut between fridge and freezer. If it’s new, call warranty service
Posted on Nov 01, 2018
4 Suggested Answers
  • 78 Answers
SOURCE: Forgot my username cant log into laptop, help
Posted on Sep 22, 2014
  • 235 Answers
SOURCE: Refrig cooling
Sounds like the evaporator fan is not working. Check to see if you can hear the fan running in the freezer. If not running, try removing the panel in the back of the inside freezer and manually spin the fan blade . This sometimes works.
Posted on Jul 03, 2009
iwillfixforu
  • 619 Answers
SOURCE: I have a ge externa refrigerator that does not
If the fan is working fine the next thing to check for is heavy frost on the back wall of the freezer section toward the middle to bottom area. If you have frost there you will need to remove the panel and with ref. off use a hair dryer to defrost the ice from the coils. After the ice is defrosted you will see a defrost heater at the bottom of the evaporator coils. This will be your problem Part number 51x10101 at about 64.00 or less. Hope this helps and good luck. Rick
Posted on Mar 09, 2010
heatman101
  • 43501 Answers
SOURCE: top freezer workin, bottom part of fridge not
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Posted on Sep 30, 2010
My frigidaire refrigerator does not seem to cool no freeze
If you have a sxs refrigerator then you have an issue with the damper door/switch not letting cool air from the freezer section to the refrigerator section. If you have a top mount freezer refrigerator unit, then you have a problem with the top venting system from the cabinet's ceiling.
Jul 27, 2012 | Refrigerators
My freezer is workin but my fridge isnt cooling. food n milk went sour.... whats goin on?
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Jun 02, 2011 | Magic Chef CTF1826AR Top Freezer...
Hi got a preistage fridge freezer and the freezer has all defrosted over nite but the fridge is still workin but not very cool is it broken?
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
heatman101
Jan 16, 2011 | Refrigerators
Top freezer workin, bottom part of fridge not cooling at all
heatman101
Sep 30, 2010 | Kenmore 64802 Top Freezer Refrigerator
Refrig cooling
Jul 03, 2009 | Refrigerators
Westinghouse Wse6100WA side by side Fridge-icing up/not cooling
This is a bad design flaw, the fridhe is cooled by fan forced air from the freazer. Two ducts vent into and out of the fridge fron the freezer and ice can block them up (which you can find if you take off all the plastic at the top and back of the fridge).
Hence, when they block up, the frindge does not cool, hence the thermostat tells the fridge to keep running which makes the freezer colder and colder, making the blockage worse.
You need to not only fully defrost the freezer (which can be done quicker by removing the plastic panel in the back of the freezer and using a hairdryer) BUT also fully dry the fridge before turning it back on.
To stop it happening again, avoid puting unvovered liquids or hot items in the fridge. Also avoid leaving the fridge and freezer doors open for long especially in humid conditions. As I said, it's a bad design.
Mar 31, 2009 | Westinghouse WRS3R3EW 33" 22.6 Cu. Ft....
I have a Whirlpool side by side fridge freezer (brand new only 2 days old) the alarm is going off and the two lines side by side on the freezer side are flashing?
The alarm is set off when the freezer is out of the differential range of the setpoint. In other words, the freezer is still too warm. If you press the alarm button, the sound will stop but the light will stay on. If the unit is working correctly and cooling properly, this light should go out once the cabinet temperature gets close to the setpoint temperature. Hope this helps you.
Mar 04, 2009 | Freezers
Brand new GE wont get cold
Sounds like the installers had to remove the doors when the unit was delivered. If they did they might not of hooked the wire harness up at the top of the door hinge or damaged the room thermisters at the top of the door hinge system. Also there is 2 magnetic switches under the top of the doors, you might check the wires on them as well.
Jun 29, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
18 cu inch refrigerator ge hotpoint
my freezer is set higest and meats frozen ice cream soft the refrigator part is set on #9 but everything is not warm but just a little cool
Jun 16, 2008 | GE GTH18JBR Top Freezer Refrigerator
Refrigerators Logo
565 people viewed this question
Top Refrigerators Experts
Marvin
Marvin
Gil Shultz
