Question about Mitsubishi WS-55513 55" Rear Projection HDTV
Mitsubishi 62inch diamond series
Blinking, won't turn on 2 years old, I have reset,unplugged ect. HELP
  • 1 more comment
  • deepthreat Nov 26, 2007
    my tv has menu and enter buttons if thats the same then that did'nt work
    any ideas
    my model number is ws65813
  • 1,153 Answers
Do self diagnosis test at
Posted on Nov 26, 2007
1 have a 6 year-old Mitsubishi model WS-48511 series 1080 rear projection TV that now won't turn on. A few days ago we shut the TV off, and now when i plug it in the blinking green power light...
This is called the blinking green light of death-----only one of two things can cause this problem.
First: remove front speaker grill (IT PULLS OFF) AND remove inspection plate behind it; look for the two bundles of wires coming down and to the right from the front keyboard of the set.
Unplug both plugs you find (different and marked so you cannot mix them up-----the idea is to take the front keyboard out of circuit-----set will still function with remote as receiver is behind front screen)
Try (after 70 seconds) to turn on with remote
If it comes on---defective reset button on front keyboard----use set only with remote or remove and remove actual reset switch---it is located behind and part of frame for screen----entire front screen would have to be removed to get at it.
Second: if disconnection of the front keyboard does not help, the DM unit is bad.
As you look from back of set it is large metal box at extreme left side.
The blinking light is the unit trying to "Boot" up-----these have a problem where caps and a few other parts in that unit fail-----kits on the net are available----Mitsubishi no longer sells or services these units but PTS Electronics does repair them.
Let me know if you have questions and try disconnection of the front keyboard FIRST.
Jan 20, 2012 | Mitsubishi WS-55613 55" Rear Projection...
Had power outage, then when power back on in house, tv green light keeps blinking even after unplugging and pressing reset button and attempting re turn on. we use a surge protector, tv is 65"...
This is a solution that was previously posted by Fix-Ya Guru Freetek for the exact same TV and same situation:
Mar 05, 2011 | Mitsubishi Televison & Video
My 52" Mitsubitshi Diamond series will not turn on. It has a blinking green light that says timer underneath and the system reset button had not effect either. The TV is only six years old and rarely...
Probably a blown pico fuse on the circuit board, convergence amplifier issue, or blown HOT transistor. Could also be a solder connection on the pc board other bad component. Count the blinks and note any pauses in blinking. This could be a trouble code. Type into google your tv and model number and the words "troublecode ## " if you had one or "steady blinking green light" if it just continuously blinks wit no pauses. See where that takes you... Hope that helps some.
Jan 08, 2010 | Mitsubishi WD-52525 52" Rear Projection...
Green light comes on then goes right back off.
The TV indicates an error code 22 (short circuit protection). Check 2 STK392-570 convergence IC for shorts and 5amps pico fuse for open. I usually replace both STK's.
Dec 25, 2009 | Televison & Video
Sounds like your TV is overheating. How dirty is the filter on the side? Is the fan on the back turning ok:? Does it look real dirty? Is so, a good cleaning is in order. Also, there is a fan under the lamp. Can you determine if it is working...the air flow may be obstructed (from the clogged filter) and it takes some additional time to cool.
Jun 21, 2009 | Mitsubishi WD-52525 52" Rear Projection...
TV won't turn on
Ready? The solution is = Replace four capacitors inside DM module 1000mf / 25v high temp. For details.........Look @..
Oct 24, 2006 | Mitsubishi WS-55613 55" Rear Projection...
Mitsubishi WS-55513 55" Rear Projection HDTV Logo
54 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
