Question about Refrigerators
Hotpoint fridge freezer model number ff72p fridge not getting cold
Only going to 16 degrees
    Sergeant:
  • 351 Answers
Remove inner wall in freezer to see if ice has built up on the coils. If the defrost heater has failed result will be ice build-up on the freezer coils and lack of air flow in refrigerator so no cooling.
Posted on Oct 31, 2018
SOURCE:
  • 139 Answers
SOURCE: Freezer ok fridge warm (15 degrees)
You have a hotpoint mistral f/f i take it in silver..
Check to see if the fan is running at the bottom on the back of the fridge its next to the compressor behind the panel ...
if the compressor is running and the fan is not then your fault is the fan..
IF the fan is running then its the sensors...
These are located in the freezer section, pull out the draws and remove the panel behind it.... six screws.......... you will c threes plugs at the top ledt hand side.. the yellow one is for the fridge the green one for the freezer.... replace both if your freezer is not working...
Also just below the freezer door there is a panel remove the panel and use a vaccumm to clean the fluff that has built up on the coils..
hope this helps if you need anymore help dont hesitate to ask...
by the way the sensors are called evap thermistors...
Posted on Jan 11, 2008
  • 90 Answers
SOURCE: FRIDGE/FREEZER MODEL: SR42NMB Multi Frost
You have a clogged defrost drain tube. best way is to thaw unit out. Your vents are being blocked so no air flow is pushed down.
Posted on Jan 05, 2008
dididsaythat
  • 291 Answers
SOURCE: Hot Point Side by Side. Freezer works, Fridge not cool enough
check freezer for frost build up and if fan blowing, check condenser make sure clean, and fan blowing, check vents in refrig. make sure no blockage, freezer control should be in the middle setting, you can try turning that to Warmer Freezer allowing MORE air to refrigertor side.
Posted on Sep 03, 2007
yalmer
  • 552 Answers
SOURCE: I have a Hotpoint Mistral
It is possibly the fan hitting any overformed ice.
defrosting by shutting it off overnight would be the best to do first.
Or at least shut it off for a few hours.
Posted on Mar 05, 2008
  • 24 Answers
SOURCE: samsung fridge freezer model number
Hi just wondering if you figured out the problem with your Samsung fridge yet.
It is definately a problem with the defrost part of the fridge. After approximately 4 to 10 hours dependent on many different factors it enters into defrost mode to get rid of any excess ice in both the fridge and the freezer. During the defrost stage the compressor will not run. If any fault occurs during the defrost stage the fridge will not restart unless you turn it off and back on again which restes the pcb and takes it out of defrost mode and the timer starts again.
Please let me know how you went with it.
Posted on Oct 26, 2008
I have a hotpoint FF72P fridge freezer. it comes down to temperature (-22/+4) without any problem, but after this the compressor won't cut in.
takes time for the temperature inside the fridge -freezer to normalize after doors are being left open
turning off a fridge freezer on and off wont help it
it takes time to for the thermostat to kick start the compressor
and more time to reach the freezing temp lost
if you are certain the thermostat is damaged
call in a service man
have the thermostat replaced and have them check
the gas in the system is running the correct pressure
Jul 31, 2016 | Hotpoint Refrigerators
Top freezer model: the freezer works but the refrigerator stays at about 50 degrees
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Apr 17, 2011 | Hotpoint HTS18 Top Freezer Refrigerator
Freezer is freezing cold... but refrigerator is not cooling good on side-by-side Hotpoint Model HSS251FMDWW. What number should it be set on??
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Mar 31, 2011 | Hotpoint Refrigerators
Hi,im having trouble with a hotpoint fridge,model number ctx14cybjrwww.Problem is the fresh food area isnt cold,yet the freezer area is.Thx for any help
heatman101
Mar 15, 2011 | Hotpoint Refrigerators
Freezer working but fridge not cold
If the freezer really is operating at its proper temperature of +- 5 degrees F, then the likely problem is the failure of the fan that circulates the cooled air between the two cabinets. This fan is located behind the liner of either the freezer or refrigerator and is not an expensive part; the labor may amount several times the parts cost.
Since you did not list the model number for your unit, you will have to search on your own to find an illustrated parts breakdown of your fridge. You might start at the Sears parts department website as they have a broad range of manufacturers and models displayed with line drawings which can help you assess the difficulty in either doing it yourself or having it done.
Jan 25, 2010 | Hotpoint Refrigerators
Weve lost the instruction manual for our Hotpoint Fridge-Freezer
Sorry, no secret. The fan wasnt working so we called an engineer who bypassed a sensor. Now it works perfectly again.
Mar 22, 2009 | Bosch Freezers
I have a Hotpoint Mistral frost free fridge freezer model FF72P (according to the sales invoice). The freezer is working fine but the fridge is not cooling. The fan that circulates the air is working...
Mar 05, 2008 | Refrigerators
Refrigerators Logo
54 people viewed this question
Top Refrigerators Experts
Marvin
Marvin
Gil Shultz
