Problem for Coffee and Espresso Makers
Generic problem for all Coffee and Espresso Makers
Seaco coffee brew malfunction
I have a Seaco Primea touch plus Cappuccino machine, I have also wasted several hundred grams of coffee beans because the machine grinds and goes through all the functions but does not pass water through the beans but throws the dry grindings into the waste container and then goes back to main menu select. After the grinding the machine makes a noise like compressing but does not rerach the point of activating the water. The Brew group is spotless and I gave used the supplied grease but found the grease points in the manual very vague with arrow points pointing to a complex system. appreciate any help
Solution #1
posted on Aug 04, 2009
Rank: Guru
Expert
Rating: 86%, 326 votes
Have you tried to clean the shower in the brew group, then adjust the grinds about 2 numbers coarser and test?
Popular Solutions for Coffee and Espresso Makers
Questions and Unsolved Problems for Coffee and Espresso Makers
Where in North-Central London can I purchase a replacement gasket for a 1-2 cup vigano stovetop...
(More)
Where in North-Central London can I purchase a replacement gasket for a 1-2 cup vigano stovetop espresso maker?
overflowing can't calibrate half brew
just purchased the B145...we already own the B70 for the past year...the B145 reservor, there is a...
(More)
just purchased the B145...we already own the B70 for the past year...the B145 reservor, there is a part inside that we have on the B70 but is not in the reservor of the B145...the machine does not seem to be getting water? Help!! Karen
kuerig b2003 has yellow & green lights on and red light flashing what's wrong with machine
