Question about toner Office Equipment & Supplies
How to install toner - toner Office Equipment & Supplies
    Sergeant:
  • 351 Answers
Open toner door and look for instructions in the machine or check for instruction sheet that came with the toner.
Posted on Oct 31, 2018
SOURCE:
Installed toner cartridge samsung clx6200fx and it keeps saying install toner what is wrong
Did you get a Samsung toner cartridge or an off brand? Toner cartridges have small chips that tell the printer how much toner is left.. Not all of those chips will work correctly.
Mar 28, 2016 | Samsung CLX-6200FX Printer
Tip
Konica Minolta Copier service code C0070 C-0070
This service code C0070 is a universal code used by Konica Minolta to indicate a toner bottle rotation failure. These machines add toner by rotating the toner bottle that you install in the machine. Most of the time this code is caused by a toner cartridge that has been installed incorrectly or has become dislodged from it's holder. To clear the code open the front door or toner door and remove the toner cartridge/bottle from the machine. Close the toner door and if needed open then close the front door to reset the code. Let the machine run. This may take several minutes and will allow the machine to bring the toner bottle receptacle into it's home position. Once the machine stops running completely, then you can re-install the toner cartridge. If the code does not come back you are ready to go. If the code came back after removing the toner but before you re-installed it then you have either a dirty rotation sensor or a bad toner drive motor and will need service.
If the code comes back after the cartridge is re-installed then there is either a priblem with the cartridge or with the toner bottle drive.
Most of the time though the problem will be resolved by the outlined procedure.
on Jan 04, 2010 | Office Equipment & Supplies
BROTHER DCP7055 PRINTER SHOWS REPLACE TONER EROR
When replacing the toner cartridge, you MUST install a brand new, unused genuine Brother toner cartridge in order to reset the toner status. Swapping toner cartridges from one machine to another or installing a partially used toner cartridge may cause this problem. Brother machines control their image quality for the most suitable print quality by monitoring toner consumption. If you install a partially used toner cartridge, your Brother machine is unable to recognize toner consumption correctly which will cause this problem. Therefore, when you replace the toner cartridge, please use a brand new toner cartridge, not a partially used toner cartridge from another machine.
Jul 26, 2012 | Brother Office Equipment & Supplies
C0070 machine trouble
Good Luck and Thank You for using Fixya.
Jan 08, 2011 | Minolta EP4000/5000 CS/PRO Copier
Have a Konica Minolta 2430 DL and it ask me to install blk toner after install toner it has error line 2408. can you help me?
2408 means that the toner cartridge you are trying to rotate to is already in the top position or you need to install another toner cartridge before you can rotate to the color you want to replace.
To fix the toner not installed message clean the three contacts on green chip on the right side of the toner cartridge. You may see black lines on them. Use an eraser or rubbing alcohol.
Nov 11, 2010 | Konica Minolta magicolor 2430 DL Laser...
It doesnt print the first page and its a minolta cspro 3000 and the error code is c0070
This service code C0070 is a universal code used by Konica Minolta to indicate a toner bottle rotation failure. These machines add toner by rotating the toner bottle that you install in the machine. Most of the time this code is caused by a toner cartridge that has been installed incorrectly or has become dislodged from it's holder. To clear the code open the front door or toner door and remove the toner cartridge/bottle from the machine. Close the toner door and turn the machine off then on to reset the code. Let the machine run. This may take several minutes and will allow the machine to bring the toner bottle receptacle into it's home position. Once the machine stops running completely, then you can re-install the toner cartridge. If the code does not come back you are ready to go. If the code came back after removing the toner but before you re-installed it then you have either a dirty rotation sensor or a bad toner drive motor and will need service.
Sep 29, 2010 | Minolta Office Equipment & Supplies
MACHINE SHOWING THE 0070 CODE PROBLEM
If the code comes back after the cartridge is re-installed then there is either a problem with the cartridge or with the toner bottle drive.
Jun 30, 2010 | Minolta EP4000/5000 CS/PRO Copier
Toner low we installed new toner. then message
remove plastic cover from toner yellow or any color and install toner properly.
Jun 04, 2009 | Brother MFC-8460N All-In-One Printer
Error 2408
Jul 11, 2008 | Konica Minolta magicolor 2430 DL Laser...
Top toner Office Equipment & Supplies Experts
Fred Sops
Marvin
Marvin
NOEL
NOEL
Are you a toner Office Equipment and Supply Expert? Answer questions, earn points and help others
