Question about Elite Televison & Video
What are the exterior dimensions of a Kenmore elite side by side refrigerator model # 10655602400?
It is about 12 years old
SOURCE:
VANMAN69
  • 23 Answers
SOURCE: freezer works ok.refrigerator temp varies from 39 deg.to 60 deg.
check to see if there is frost in the back of the freezer if so you have a defrost prob..
Posted on Jun 29, 2007
SOURCE: kenmore elite refrigerator, model # 59676534500
I went ahead and signed up for Sears' service warranty since I knew I had to get someone to come out.  IT costs $200/yr.  They say it covers everything, but when the technician came out, he told me that it just covers $500 per visit.  He said that a new motherboard and the labor alone was going to make it $498.  Anyway,   he had ordered a new motherboard. Apparently the motherboard wasn't working.  It is located in the back bottom left side of the refrigerator behind the panel.  There is a compartment on the lefthand side that slides out and houses the motherboard.  He put that in and also had to fix the fan that is in the back of the freezer.  That fan is the one that sends cool air up to the refrigerator part. When I had looked at the fan before the repair man came, it was not moving at all.  So at least take a look at the fan in the freezer.  Just take out the freezer drawers, and the fan is located in the top center of the freezer behind the compartment cover.  Maybe that's the problem with your refrigerator, the fan.  Hope that's all it is. Good luck!
Posted on Jun 25, 2008
SOURCE: Kenmore 20 porcelain plus refrigerator
5' 6" Tall
32 1/2" Wide
28" Deep
I bought that old fridge at a garage sale for cheap. It's been enjoyed for me for just over a year. :)
Posted on Aug 21, 2008
  • 14 Answers
SOURCE: Replacing the Ice dispenser motor on Kenmore elite refrigerator?
There is a small door under neath ice maker shelf (literally) w/ 2 small screws that keep it in place,or a button that can release ice maker on the rt. side of machine. Good luck!!
Posted on Apr 04, 2009
  • 2699 Answers
SOURCE: my kenmore side-by-side refrigerator is
all it does is the evap fan blows cold air from the freezer into the fridge section and returns through the bottom air vent,so if there's ice there most likely one of the doors was left open,check the freezer for frozen water droplets on packages or on the walls and shelves of the machine,if you don't see that open the freezer door,if you don't hear the fan blowing you could have a bad evap fan motor.if the fan is blowing in the freezer from the bottom remove the second draw or bin and put your hand on the back inside wall of the freezer,if there's frost or like snow on the back wall you have a defrost problem,bad defrost thermostat,defrost heater,timer or board depending on what model you have,if the fan is blowing and you don't see any problems that i talked about you could have a bad damper,on some machines there's a damper door that opens and closes to let cold air into the fridge section,if it's bad it won't open and no cold air can blow in from the freezer,if you think the door was left open,remove anything that's in the way,in the freezer side and the fridge side,shut the machine down or unplug it and with a hair dryer melt out the ice,don't keep the heat in one place for to long,you can melt the vent if it's plastic or styrofoam,after you think it's melted out start the machine and put your hand up in the left hand corner in the fridge section and see if you can feel any cold air blowing in,there could be ice up there too,next time send the model number so i can look up your model,on a side by side you'll find the tag on the right hand side wall in the fridge up near the ceiling or on the ceiling near the light.hope this helps,if you have another fridge you could move the food and just shut the fridge down with the doors open and let it melt out on it's own overnight.good luck
Posted on Sep 05, 2011
Kenmore Elite 106.54609300 What are the exterior dimensions? H,W,D I need to replace with a similar sized refrigerator in an enclosed spot. Can't find this info anywhere.
This is not credible request: Manuals are available from SEARS...
Use your measuring tape... and then go to the MANUAL and add the required clearances
http://www.searspartsdirect.com/partsdirect/part-model/Kenmore-Parts/Refrigerator-Parts/user-manuals/manual-downloads/Model-10654609300/0582/0165000?modelNumber=10654609300&diagramPageId=&documentId=26037129
STRAIGHT FROM THE OWNERS PDF
Door ...
shipping dimensions... seriously!
Part Information
This manufacturer-approved door assembly (part number L2255526LJ) is for refrigerators, including Kenmore refrigerator model 10654602300.
Unplug the refrigerator to disconnect electrical power before installing the new door assembly.
Follow the instructions in your owner's manual or installation guide to remove the existing door and install the new door assembly L2255526LJ
This Refrigerator Door Assembly part #L2255526LJ is guaranteed to fit your KENMORE REFRIGERATOR #10654609300
Door shipping Specifications
  • Category: Refrigerators and Freezers
  • Shipping Length: 77 in
  • Shipping Width: 28 in
  • Shipping Height: 13 in
  • Shipping Weight: 45 lbs
for questions or assistance, call 1-800-733-1381
M-F 6:30 a.m. - 10:30 p.m. CT
Sat 7:00 a.m. - 9:30 p.m. CT
Sun 7:30 a.m. - 9:30 p.m. CT
(Se Habla Espa?ol)
Jan 03, 2016 | Kenmore Refrigerators
Kenmore Elite 795-78029. Why do I have water spraying from behind the supply line connector on the back of the refrigerator?
the valve or its supply line is leaking --damaged or loose connection if your able to isolate the problem say its the valve you can change the valve with simple tools same if water line can buy a repair kit
Aug 11, 2015 | Refrigerators
What is the lifespan of a Kenmore Elite Model 795?
Free Kenmore Refrigerator User Manuals ' ManualsOnline ...
kitchen.manualsonline.com > ... > Kenmore > Kitchen Appliance Kenmore Products 1 - 50 of 357 - Kenmore Refrigerator User Manual.
Jul 19, 2015 | Kenmore Refrigerators
What are the dimensions of the kenmore elite 22.4 cu.ft. bottom freezer refrigerator?
26'wide X 19" deep X 21'' front to back. I'll never have a side by side again!
Jul 04, 2014 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
I have a kenmore elite refrigerator about 10 years old, side by side model 50599003, still blows air but both frig and freezer are blowing warm are. condensor?
Check for clogged condensor coils underneath rear of fridge.
Thank you for using fixya
Leo Ponder
Please rate me if this helped.
Jul 16, 2011 | Refrigerators
Kenmore Elite Trio Fridge Not Cooling
check the over-load/contactor on the side of the compressor,remove it and shake it if it rattles,replace it
Nov 01, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Televison & Video Logo
Top Elite Televison & Video Experts
Akbar Mughal
Akbar Mughal
 steve
steve
Are you an Elite Televison and Video Expert? Answer questions, earn points and help others
