GE GSH25JSTSS Stainless Steel Side by Side Refrigerator Logo
Posted on Nov 26, 2007
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Ice doesn't dispense and both freezer and refrigerator aren't cold enough
We've had our GE GSH255JSTSS fridge for about two years now. Earlier this year the freezer stopped dispensing the ice cubes. It would still make ice but when we press on the dispenser it wouldn't do anything. After a while, the water started not to work. It would start making a clicking noise and the water would shoot out sporadically with each click. NOW, this last week the freezer stopped working. We noticed food starting to defrost. On top of that, the refrigerator side is not as cold anymore. Please is there an inexpensive way to get this fixed? Help!
  • Dee3269
    Dee3269 Dec 02, 2007
    Thanks for the solution! I spent $150 (with rush shipping) and the husband installed it and now everything works again! WOO HOO!
Anonymous
Level 2:
  • Expert 213 Answers
  • Posted on Nov 26, 2007
Anonymous
Expert
Level 2:
Answers
213
Questions
Helped
215620
Points
886
Yes. pull out the frig and look on the back. facing the back on thr right hand side there a rectangle metal plate. under that plate is the main computer board that controls the whole thing. they have been causing alot of problems one of which is the one your having. replace that board and your problem is solved
My GE fridge TFG 27PFXa Ice maker/water dispenser does not work.
Test and make sure your freezer section is getting to 0° and -5° often times with this problem I find the freezer section just not getting cold enough due to a condenser needing cleaning or condenser fan not working at the right speed Other items to test make sure refrigerator has 4" inch of clearance behind and possibly side but behind is absolutely a must
Ge bottom freezer not freezing
Check to see that the evaporator is not covered with layer of ice. The latter serves as an insulator and prevents freezer temps from going down to about zero degrees. If the defrost heater/timer is defective that will certainly be a cause. Since the freezer air is not cold enough to freeze, then the refrigerator temps are also high. Using a digital thermometer will confirm this.
Leaking door gaskets can also be responsible for higher internal temps
1helpful
1helpful
2answers
My fridge keeps freezing my food
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
GE fridge fan clicks, ice dispenser not working
Main control board problem . Pt # WR55X10656 . The freezer fan motor , works off DC voltage . The board is not giving it enough voltage . The main board , also controls the dispensor board .
1helpful
Freezer is cold but not keeping icecream frozen.
If, the fresh food section is 34- 38 degrees, then the freezer should be cold enough to keep ice cream solid. All of the cooling capability comes from the freezer section. I, personally, would not waste time or money on a ten year old box. Ten years ago it cost $1000, so, the outlay is $100 per year. Dump the old refrigerator and get a new one.
My GE side by side fridge/freezer is working, water dispensing ok, but not making ice. I switch off the fridge, than ice maker but still not making ice. I try all the hints from Manual but no luck. Water...
fill the ice maker with water manually, if you have ice in the bucket you know that the ice maker is working , after check the water valve if is opening , if it is replace main board
2helpful
GE Profile Freezer not cold enough
VACUMM THE COILS UNDERNEATH THE THE FRIDGE THEY MAY BE CLOGGED WITH LENT AND DUST...... HOPE THIS HELPS
GE side by side. Freezer cold, fridge kinda cool
Generaly the control board controls everything sometimes you have a bad thermister GE has a help line I beleive it costs 20.00 bucks but you will need a meter and know how to use it and they willl talk you thru the repair .
Top Refrigerators Experts
vince
Johnny 1000
