was considering buying this kind of vehicle for 800 dollars but it needs tires, rotors, main seal, winshield, brakes, and inspection 100,000 plus miles
what yr? make shure is dosnt have coolant and oil mixed. if thats ok then make shure trans shifts ok, are you a do it you self. if so doing brakes youself can save you a little money. if this is a pre 1994 explorer they had there fair share of oil leaks,a.c.problems,some wiring concerns. depending on what year i personnaly like the explorers....sooner or later all ford explorers with need at least some new radius arm bushings,
Was this helpful?
Yes
No
1 person thought this was helpful
Popular Solutions for Pro-Fit Pro.Fit Fo 71 02 Ford
I have a 93 Merc Sable. I just replaced the battery, There is not activity at the Starter. There is...
(More)
I have a 93 Merc Sable. I just replaced the battery, There is not activity at the Starter. There is no clicking, nothing. The light come on, radio, rest of the electrical.
It acts like there is a Fuse or a switch relay somewhere. Like the park indicator on the steering column.
Thanks
we had rotors and pads put on our 2006 explorer but now the brakes are making a pretty constant...
(More)
we had rotors and pads put on our 2006 explorer but now the brakes are making a pretty constant noise when pulling out of roads etc. did they put wrong pads on
I have replaced both the starter relay and the ignition switch, and no change. I have even tried...
(More)
I have replaced both the starter relay and the ignition switch, and no change. I have even tried activating the new ignition switch manually to rule our wearing of the rod which pushes the switch. New battery, new relay, new ignition... no luck. If anyone comes up with anything I would LOVE to know what the hell the fix is. Ford is stumped. I am supposed to go through emissions testing, and cannot because they won't test if I have to start it at the relay. I now have a worthless car I cannot drive because I cannot test to re-register. I expire tomorrow (Saturday).
