Question about Refrigerators
Hi my F600lm fridge freezer trips power I checked pc board I found 47u 450v capacity bulgy i wonder what could be the problem, please help
    Sergeant:
  • 351 Answers
Capacitors often bulge out when they fail. Need to replace this item, get from electronic parts store.
Posted on Oct 31, 2018
SOURCE:
  • 883 Answers
SOURCE: fridge is tripping fuse box
if this is a new problem that suddenly occurred, then trust the fuse box...the frig has a problem. Most likely a compressor motor that has been electrically damaged...could have been power surges from utility or lightening or unknown. It also could be a wiring problem in the house...mice have been known to chew through wire insulation...they feel the warm wires and are fooled into believing the wire is a live food source and start chewing. A test of this wire problem is to remove the frig and plug in something that will demand close to the same current...(should also contain a motor)...read the frig's label on back of unit.
Posted on Jul 29, 2007
bobotfel
  • 241 Answers
SOURCE: samsung fridge RS2630SH, side by side, icing up on freezer.
You have to pull out the sensor from the board and test with tester, both sensor should read the resistance of 10,000 to 20,000 ohms. The reading that you show is very low it means that the thermistor is out of range and need replacement.
Posted on Mar 08, 2008
robotek
  • 1512 Answers
SOURCE: suddenly tripped off house
Hi akula, 200 ks to a fridgie, LG appliance, you must be in Australia;) Is it the earth leakage circuit breaker operating. If so, then you have a leakage problem to earth from the heater pad(not quite sure what that is, but this problem will need to be repaired. Am doing some research to see if there is anything that can be done without just getting a new fridge. Back to you soon.
regards
Graeme
Posted on Mar 21, 2008
philbran
  • 242 Answers
SOURCE: Fridge on Fridge freezer not working
Ok there is a drain pan under the evap. coil under the fan that may be clogged and full of ice there is a 3/4" hole the water drains out of that needs cleared if there is a puddle of ice over it , the ice will also effect the airflow traveling down the duct to the fresh food section of the unit.
If there is no ice puddle at the bottom of the refrigerator then make sure the unit is cooling well by making sure it has been running for 10 min. or so and checking the coil in the freezer , it should have a small layer of frost on it showing its getting cold the whole way through it. Let me know how this works.
Phil
Posted on Jan 02, 2009
SOURCE: Whirlpool Gladiator Freezerator not cold
Just had the same problem on my Freezerator, the compressor would cycle on for a few seconds and then off for about 5-10 minutes. No cooling. Replaced the overload sw and the start capacitor and system running cold and tru. Beer cold again, 0deg in freezer. Parts are available on the web, P/n 2169373 for the capacitor and 213615000 for the switch and housing...may be different # for the sw....PTM
Posted on Aug 15, 2009
I recently bought a 100uf 450v capacitor to replace a 68uf 450v capacitor. Unfortunately there is no power being fed to the TV when plugged in. I was told by a local TV repairman that the uf rating...
The fault to your TV might not due to a defective capacitor. A higher capacitance valued capacitor, won't do nothing wrong. But as the capacitance value increases, the size of the capacitor will too increase. That's all. Check the fuse at the power supply regulator board. If it is found opened, make sure that something wrong with the power supply regulator board. Without rectifying the fault, never replace a fuse, as it will make things worse. If you wish to get more details, check this link. http://electronicshelponline.blogspot.com/ Selecting the view option, either to Mosaic / Time slide, can be selected by the drop-down list, at the top left of the display window, will make surf easy. You can also do a search, by type in the brand name/model number/IC used, in the search box at the top right of the display window.
Oct 17, 2013 | Akai LCT3201AD 32 in. LCD Television
Xerox Phaser 8550 tripping RCD on warm up
IF the warranty is still in effect, call for service.
IF no warranty, then check the heaters for the solid inks.
Probably a bad element, or a shorted element.
Unless you are skilled with electrical meters, V-O-M type,
this could be dangerous.
DO NOT ATTEMPT to troubleshoot this with power on.
IF you can use a meter, with the power OFF,
check for continuity and resistance with multi-meter set to Ohms.
BE CAREFUL!
Electricity can KILL!
Jul 27, 2012 | Xerox Phaser® 8500, 8550, 8560, 8560MFP...
Hi, was wondering if you could help. I have an Electrolux fridge Model ER6632I that has suddenly stopped cooling. This fridge is approx 8 yrs old. I opened up to the rear of fridge and found that...
Seems that the compressor has some fault within the unit as it takes in more current under pressure. Sometimes it can be due to fault within the compressor, failure of the valve , O-rings. Now shut down the fridge for about 6 hours and then plug in the fridge to start. Observe cooling to happen in about one hour and ice to from under three hours.
Earlier make sure that the thermostat was set to normal mode for freezer and fridge. If there is no ice formation we have a big issue as the compressor and gas must be checked out. , if RPM of motor is low check capacitor.
Please check this link for tips :
http://www.espares.co.uk/advice/fridges-and-freezers/a/2
Jul 25, 2011 | Refrigerators
Hi there, Just wondering if you can help fix our fridge - LG model no: GM-589VW, total capacity 589 ltrs. The freezer has stopped working completely (its been a week now) and the refrigerator is not...
The defrosting heating element may have burnt out, if so there should be ice build up in he freezer and would cause poor cooling performance in the fridge side.
Please rate my response.
Jan 15, 2011 | LG Bottom Freezer Refrigerator w/...
I have a whirlpool side by side fridge/freezer model 6ED22PKXFW00 and every time the auto defrost kicks in it trips out the circuit on my power board. I'm chasing an electrical drawing to disconnect the...
the reason for the power trip is your element use to defrost the freezer is blown and earthing out hense when it goes into auto defrost it will trip the main power
simple repair replace the defrost element
best of luck merry christmas
please rember to rank this advice
Dec 07, 2010 | Whirlpool Refrigerators
Please help my indesit ta 5 fnf s is dead with no warning. no lights no power nothing. its not fuse power or socket
Had the same problem with my TA5FNFS once you have confirmed as there is power in the wall socket and the fuse in the plug and cable are ok, I found as the PCB control board had burnt out costs about £60 for a replacement board
Apr 30, 2009 | Freezers
Zanussi fridge freezer not cooling
no, its probably weak capacitors which provide power to switch the relay. Take the control board out and ask a friendly TV repair tech to change the capacitors
Jan 22, 2009 | Engel Freezer 22 Qt. Fridge/Freezer
Suddenly tripped off house
regards
Graeme
Mar 21, 2008 | Refrigerators
Bulbs and bottom pcb blew, replaced but still not working
the start and run capacitors of the compressor can go short circuit and cause a big spike that can blow the bulbs, trip fuse etc. Inspect the capacitors for splits etc, you may well find that the start cap has blown and so there will not be enough current to get the compressor running.
Mar 18, 2008 | Zanussi ZX99 / 5 Bottom Freezer...
Refrigerators Logo
48 people viewed this question
Top Refrigerators Experts
Marvin
Marvin
Gil Shultz
