Question about Irons
I have an old kelvinator laundromat 5, and no manual. the three buttons that are push in and out marked 95, E, and no iron...are they on when depressed or not?
    Sergeant:
  • 351 Answers
Most buttons are ON when pressed, based on human engineering principles.
Posted on Oct 31, 2018
SOURCE:
Wet steam coming out of iron
You have to take part the iron by unscrewing the three bolts on the side handle with a small phillips driver. Then loose the allen screw on one side of the black thermostat wheel to unloosen it. Then take out the two bolt plastic protectors under the handle and unscrew the two allen bolts, carefully separate the top from the botton of the iron, carefully not to pry loose the cables from the top to the hot shoe.
On the back you will see a small white square box, that is the thermostat, which has a button on top, all you need to do is to push it in. This will make the iron heat up unless you have a thermostat failure (Black wheel with temperature indicators), which you will need to order the part and change it.
Mar 07, 2013 | Reliable i30/120V Professional Steam Iron...
"My rowenta DG9540 iron won't stop steaming. It starts as soon as it is switched on regardless whether the steam button is pushed in or not. What might the problem be?"
1) check the ejection button of the stems for particles, has blockage the mecanism by using hard water to due mineral deposit clean it.
2) other wise you must go to some repair shop for fix it.
God bless you
Jul 11, 2012 | Irons
My Morphy Richards Jetstream is about 5 or 6 years old & works fine except that when I first use the steam I get brown water marks on items. This means I have to wash them again. What can I do to solve...
Try cleaning the inside of the water holder it might just be calcium built up, use white vinegar to clear it and you'll prolly be fine. Put vinegar where you usually put the water and heat the iron up and steam the vinegar through the iron then put water, try distilled water to save this problem from happening again or try filtered water.
Jun 08, 2011 | Morphy Richards Jet Stream 42271 Iron
When I plug in my iron the light comes on but when I go to push the button to turn it on it does nothing, not even heat up. The iron is only 3 months old
Good Day!
Please open the cover of your iron and look for the thermal fuse inside.That is the only problem of your iron replaced it on the same ampere and temperature.
Thank you and don't forget to rate my answer.
May 10, 2011 | Irons
I have lost my instructions on how to "self clean"
Straight from the manual:
http://www.applianceinsider.com/storage/user-manuals/rowenta/user-manual/DX8000.pdf
Fill the iron with tap water to the max mark on the water tank.
Be sure that variable steam lever is set to minimum.
Stand iron on heel and plug in. • Set thermostat to ••• setting.
Once heated, unplug iron.
Hold iron horizontally over the sink with the soleplate pointing away from body.
Move the variable steam lever completely to the right and hold in the self clean position for one minute.
Warning: Doing this will cause steam and hot water to be ejected from the soleplate. Take all proper precautions and hold iron away from body.
• Move the iron gently back and forth and side to side until all water has run through plate.
• Carefully wipe all water and material from the soleplate with an old towel, as the water and minerals can stain the soleplate (although this has no effect on glide or performance.)
Warning: Iron and soleplate may still be very hot. Exercise care while wiping.
• Place iron on heel and leave to cool. Before using iron after self cleaning, test steam and burst
of steam on an old towel or cloth than can be discarded.
May 04, 2011 | Rowenta Professional DX8800 Iron
My rowenta iron which is about 4-5 years old starts blinking the red on-off button after only 2-3 minutes of use. Also the orange button will not stay lit. What is the problem? The red on-off button does...
your iron has a thermostat fault its this thermostat thats cutting in and out that puts the red light on it could be fixed but that wont be a cheap fix best bet is to buy a new iron as that would work out cheaper
Sep 11, 2010 | Rowenta DX6700 Iron
I cannot get the iron to put forth steam when I am ironing. It isn't even a year old.
take down the iron and clean it the spring is dead probaly you can stretcth it to gain a little tension.good luck.
Nov 10, 2006 | Rowenta DX9800 Iron
Treatment of new iron
Before first use, remove any labels or stickers, on the body or soleplate of the iron. On first use only, iron over an old cotton cloth using steps 1 thru 5 below on setting 5 or above (and the SURGE button for models with that function) to remove any protective surface treatments. 1. Using a clean cup, pour water into one of the two openings in the Water Fill Hole until the level reaches the MAX mark on the Water Window (A). Refill as needed. 2. Ordinary tap water can be used for ironing. Do not use water processed through a home softening system. In extremely hard water areas, consider using distilled or demineralized water, however, use tap water the first time you use the iron and once a month thereafter to maintain steam performance.
Jan 01, 2006 | Black & Decker Quick N Easy X485 Iron
Irons Logo
165 people viewed this question
Top Irons Experts
Marvin
Marvin
Are you an Iron Expert? Answer questions, earn points and help others
