Question about Kenmore 24 in. 16259 / 16254 / 16252 Built-in Dishwasher
Dishwasher is leaking on the floor during wash cycle
My new dishwasher is leaking on the floor during a wash cycle. All the connections are fine, it looks like it's coming from the lower seal on the door???
Looks like it only does this when there is no dishes inside.
  • 1 more comment
  • paulvay Nov 27, 2007
    I have already called warranty on this. The tech will be in soon and I will let you know what it was.
    Thanks for the responses!
  • jobavens Jan 02, 2008
    Our dishwasher is leaking at the bottom of the door onto the floor. I've cleaned everything and it looks like it could be some sort of "roller seal" on the bottom of the door. Could this be the problem?
  • Anonymous Mar 29, 2014
    Water is leaking onto the floor during wash cycle
  • 290 Answers
You want to make sure it is mounted to the cabinet properly so that the door is closing easily. If there are any yellow spacer blocks on the door liner, you want to remove them.
If the model number starts with 587, there is a service kit out for some of them that leak around the door when the upper wash system is running.
I have run into several that have had the door seal installed backwards also. You should see a slight V shape in the face of the gasket.
I have also found that the door seals sometimes are overly compressed during shipping. I pull the seal out of the groove and then start it back in but don't push it all the way in, just get it started, then close the door and let it push it in the rest of the way.
If you don't see anything obviously wrong with the installation or very simple to fix, you need to call for service.
Post back and let me know what you find.
Posted on Nov 26, 2007
    New Friend:
  • 53 Answers
If this is a new dishwasher, then I suggest you call in a warranty issue on this one.
Some water is leaking under the dishwasher and on the kitchen floor during the end of the wash cycle.
Does it leak during pump-out only?
If so , must be drain hose .To see everything,remove kick plate to isolate leak. Check hose connections. Fill and drain and observe.Or run a whole cycle with kick plate off to find leak.
Good luck
Aug 15, 2011 | Kenmore 24 in. 15689 Built-in Dishwasher
I have a GE GSD 5130 Dishwasher that leaks about 12 oz of water when it is pumping out the wash water and the rinse water. Its fine during the wash and filling cycle. Is it a seal problem?
This is more likely the hose connection at the drain pump or the pump housing is leaking. You will need to remove the toe kick, place unit into a drain cycle and inspect for a leak. Here is a couple links that should help.
http://appliancehelponline.com/dishdraincircpumpvideo.html
http://appliancehelponline.com/dishwasherdrainpump.html
Jul 15, 2010 | GE GSD5130 Dishwasher
Intermittent leaking during wash cycle
is the dishwasher leaning foward,are you useing to much soap?start the dw with out anything in it let it run a few minutes open the door and see if there are suds in it if so way to much detergant
May 31, 2010 | LG 24 in. LDS 5811ST Stainless Steel...
Kitchenaid dishwasher is leaking
depends. take the lower panels off the dishwasher below the door right at the floor. Once this is done you will need a flashlight. If possible lay on the floor with the flashlight and activate the dishwasher. Look for the leak at that point. If it starts leaking in the drain cycle then the impeller is leaking and will need to be replaced. These can be a little pricey so take the model and serial numbers and call an appliance parts house for the cost and it is a little bit of a hassel to replace so only you will know if you want to tackle it yourself or buy a new dishwasher. If is leaking during the rinse cycle then the gasket at the base if the washer (where the motor connects to the dishwasher itself) has gone bad and this is a bugger bear to repair. So it's up to you if you want to repair or replace.
Good luck on repairs Hope I helped you some
Dr Berry
Feb 17, 2010 | Dishwashers
Roper Dishwasher leaks from float or float switch onto floor
you could be usiong way to mauch soap try filling only one of the soap trays or even try doing one wash without any soap at all
this unit tends to do this if you have to much soap in the unit left over from the last load...
beyond that your machine is proibaly tilted to far forward you can lift it, by lowering the front legs begind the toekick
Oct 25, 2009 | Roper 24 in. RUD4000M Built-in Dishwasher
LG 3 in 1 Dishwasher model LD2131SH showing E1, leaks water
e1 is a leakage error. you will have to find where it is leaking from...crack hose .crack motor assy.. water must be leaking
The excessive RPM of Washing Motor happened during Wash cycle due to water leakage.
Water leakage in Hose connections. Water is leaked by damages. The Motor Water Seal leakage of Sump assembly. The height of Drain Hose connection (sink-Drain Hose) is not over 20 . Impeller of the Washing Pump is worn away.
Sep 11, 2009 | LG 24 in. LDS 5811 Built-in Dishwasher
Kitchenaid dishwasher makes a crunching sound during rinse cycle
Sounds like a bearing in the pump is going. This would cause a leak be careful leak will get worst.
Sep 18, 2017 | KitchenAid 24 in. KUDS02FRSS Stainless...
Leaking water on floor during drain cycle
First the source of the leak needs to be identified. pull the machine out from under the counter and remove the left side panel exposing the blue float assembly. Turn the machine on and observe the fill cycle. if water comes out anywhere on the fill mechanism then the inlet valve needs to be replaced. once the machine has filled and begun to cycle cancel the program and drain the unit. observe closly where the leak is happening. a leak during drain usually indicated a leaking drain hose.
Feb 05, 2007 | Bosch SHU9915UC Dishwasher
Kenmore 24 in. 16259 / 16254 / 16252 Built-in Dishwasher Logo
286 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
vince
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
