SOURCE: cant program directtv remote to sony tv
See if this web sight helps in your problem
Good Luck and have a great day.
RCA Universal Remote Control-Programming Codes
Ed
NC Electronic
Mills, Wyoming
SOURCE: Sony KP-53HS10 TV Infrared remote sensor problem
Hey, I called the local Sony Authorized dealer/repair. He said the little microprocessor inside the sensor goes bezark once in awhile......soo.......unplug the TV from the wall when you go to bed and then plug it back in the next morning. It worked for me. The little gizmo resets itself.
SOURCE: vizio tv code for sony blu-ray disc player ''remote''
I put the Mitsubishi code, 04 as well for my visio 22 inch LCD. Worked just fine now!
SOURCE: pip pictture doesn t turn off
I had the same problem many times, and I don't have the original remote. Go into your menu options and select Auto-Program. It will run through all your channels, but when it is done, PIP will be off !! I have PIP!
SOURCE: Direct TV remote "tv input" button won't work with my Sony TV
I came across this looking for a similar solution for my Samsung TV, and I found the solution on ehow.com. Apparently after you program the remote for your TV you have to hold mute and select again until it flashes twice then put in 960 to make the remote control TV input too. Note you're remote should be in TV mode while you do this. It seems silly that the DirectTV guy wouldn't do this when programming the remote.
