Question about Cell Phones
How can I get the needed 191MB space
Download available but extra storage space needed. SD card in phone. Where do I get extra space?
  • 936 Answers
Delete your cache data
Posted on Oct 30, 2018
  • Rietta Dyzel
    Rietta Dyzel Oct 31, 2018
    Where do I delete cache data
  • Raj Patel Oct 31, 2018
    Depends on type of phone. For Android phones, go to SETTINGS, APPLICATION MANAGER, click on each application in turn to see storage use and delete any cache data for that app. Search google for more help.
SOURCE: Blackjack Memory
ok this might work I cannot guarantee it. first back up all of your data onto your computer. After that turn off your phone. then first hold the up button then at the same time hold hold down the power button and you should get to format mode press 1 and it will automatically format it. then it should boot up normally. put the memory card in see if it works and put all of your data back on your phone. hpe this helps with your problems
Posted on Jan 20, 2008
  • 4 Answers
SOURCE: Vista HCX Micro SD Problem
Vista only recognize gmapsupp.img files.Go to www.mapwel.biz/down.htm take MapUpload software then from mapsource select maps you want to transfer to sd card.Or directly from Mapsource select Transfer and send selected map to sd card.Maps must be unlocked.
Posted on Aug 24, 2008
nidostyle
  • 135 Answers
SOURCE: Lost of space on micro SD card
Yes you can get your space back.
Let me clear you first you lost the space due to while system is writing data in your SD micro card it is suddenly ejected or disabled.
You will do this method to retrieve you data back. You will need some things
1. Card reader for SD micro memory.
2. A software called D M comes as Hard disk tool it comes in bootable cds.
You will remove your H D for safe side to protect your hard disk data.
Put your SD card in card reader and start you computer with bootable cd that contains D M software.
When your system is boot from cd run D M and go to option in D M erase all data. This will retrieve your all space from SD. Remember you can do the same thing with Hard disk if there is any bad sector or some space not avalible or disk partion is not able to delete by any softwares.
Hope this will help you, If you have any problem regards this you can reply to me other wise don't forget to make ansewer my thread.
Regards
nidostyle
Posted on Nov 17, 2008
SOURCE: Option to use SD card as usb not available
Ignore the manual..It directs you to drill down into the settings for the sd card and set it as mass storage..no such option exists in the menu.
Follow this:
plug in usb
go to NOTIFICATIONS
touch the notification in the list that refers to the usb having been connected..you will receive a prompt to "mount" the sd card.
now you can access it.
viola.
bada bing
Posted on Nov 27, 2008
pmf1977
  • 16 Answers
SOURCE: Setup for mass storage on phone wont work
plug in your usb lead
when the phone makes its noise to comfirm lead is plugged in
a usb icon should appear on the top menu bar
hold the bar and drag it down
you should see a notification USB connected
select it
select MOUNT
there ya go you should now be able to see it
Posted on Jan 08, 2009
Just Purchased an All winner 10" tablet model #TD9300D says has internal storage (total 504 mb) (121 mb avail) SD card total (4.66 GB) (avail 4.66 GB) Can't download-no room no setting to sd card
The internal storage of that tablet (which I have never heard of before) is extremely tiny. You would need to delete any unused apps to free up space. I think that there are restrictions as to what can be saved to SD memory.
Feb 02, 2018 | Tablets & eReaders
File manager saying LOST DIR for my SD card
Your cel phone download path is the internal storage, modify the download path to SD card or move files to sd to gain space.
May 13, 2016 | Tablets & eReaders
How can I get my storage of my SD card to stop saying calculating,?
Its not about the sd card space you need to free some space on your phone internal memory first
Mar 12, 2016 | Cell Phones
How to download apps, get more storage on my lg-l38c android phone
not really
there is only so much space available and you will have to remove all those apps and games that you seldom use but take up lots of space
everything that is on the phone uses space and everything that you have but seldom use is used up space
Feb 13, 2016 | Android Cell Phones
There is no SD card in my phone....But can that be the problem
You only need SD card for storing extra data or for external storage. If your phone's internal memory has good capacity, you do not need an SD card for storing extra data.
However SD cards can be used for storing your important files externally. So if your phone doesn't support SD card, please keep a backup of your files elsewhere.
Dec 14, 2014 | Cell Phones
Cannot download anything, insufficient space on device
Hi Izabel Maritz, I want to help you with your question, just answer each of the following to the best of your knowledge and follow the solutions. 1 Smartphone or not. 2 Removable media inserted? (Micro SD card) 3 Does the Removable media device show unused space? First and most importantly if you know a Micro SD card is installed with sufficient space to save your downloads then your phone settings are set to save downloads to 'local storage' and has filled to it's max. Often you can fix this easiest by removing the card for a few seconds and re-inserting it whilst the phone not 'locked'. Most phones will prompt you asking if saves should now be made to the SD card or to leave it at 'local storage' If you answer yes to each of the above numbered questions, it is likely the browser you are using is set to download to the incorrect destination. Try Solution A below. If answers no to questions 2 or 3 of the above question skip to Solution B. (Solution A) To check this open your browser and look for the settings menu. From here it will depend on the browser you are using, but you want to look for an option related to the following. 'download location' 'file destination' 'save to external media' If you have no success or need help finding the setting for your browser please provide me with browser name. If it is the cell phone provider browser that comes default on the phone then I will need the make and model of the phone. (Solution B) If no Micro SD card is installed to your phone I would recommend buying one they are inexpensive and provide a large amount of space for things on your phone. The average phone whether it is smartphone or not does not have much 'local storage' Other solutions for B, 1 Freeing space in your local storage. This means deleting things saved to the phone itself. Music, Pictures, Ringtones, Video's, Applications could be filling the phones local storage. 2 Freeing space on your 'external media' device. This means deleting things from your 'Micro SD card' (Note. If you plug a phone smart or not into a PC or laptop usb port you may move things rather than delete them. I can assist further with that as well.
Nov 25, 2014 | Cell Phones
Low storage space on my zte score phone how to free up more space
Please go to the Settings of the device to check the Available Space on the device. Also the phone has an external memory compatibility of 32GB where in you can download the apps and save it on to your SD card. Even without deleting the data on the phone, you can transfer it to the SD card. If you don't have an SD card, then you can go to the FILER option of the device, access the Phone memory and delete the files as per your wish and that should work.
Mar 02, 2013 | Cricket Wireless Cricket Muve Zte Score...
select it
select MOUNT
Jan 06, 2009 | HTC G1
Cell Phones Logo
444 people viewed this question
Top Cell Phones Experts
Marvin
Marvin
Are you a Cell Phone Expert? Answer questions, earn points and help others
