Question about Amana Refrigerators
Owners manual Amana fridge atx518vw - Amana Refrigerators
  • Chris Huff
    Chris Huff Oct 29, 2018
    Or searspartsdirect.com
    Top Expert:
  • Amana Master
  • 6,289 Answers
Http://www.manualsonline.com/
Posted on Oct 29, 2018
SOURCE:
Lettuce is freezing, making it unusable. The Amana (bottom freezer) fridge is only set at 3 so I don't understand. I believe the moisture gauge had been in the middle so I'd moved it to low. now I just...
u have to reduce the cold air from the freezer. u have a dial with letters. turn it so the freezer gets colderf that way the ref. gets less cold air. try that ok
Feb 11, 2011 | Amana Refrigerators
My Freezer isn't getting cold. It sounds like the motor is coming on every 5 minutes or so and only staying on for about 1 minute
I suspect by your description the fridge either has a faulty overload protector or the compressor itself is seized.
If you feel like you can trouble shoot further I`ll try to assist you or you may decide to call a professional appliance technician.
**FYI, Most of the Amana fridges have 5 to 10 years sealed system warranty which would include the compressor but not the electrical starting devices i.e., the overload & relay. Check your owners manual, it is the ultimate authority on warranty no matter what anyone else tells you according to Whirlpool/Amana.**
Hope that help`s move you forward if nothing else. If so please take a second and rate the reply to your inquiry you received here at fixya.
Thank you and good luck.
macmarkus :)
Dec 07, 2009 | Amana ARB1905C Bottom Freezer Refrigerator
Amana arb2557cw condenser coils freezing, fridge not cooling
There are a few things that it could be. Do you mean the evaparator coil? This would be the coil on the inside of the freezer, the condenser is outside the unit. If the evap. coil is freezing, you could have to much in your freezer blocking air flow. You could also have a evap. fan not running. Check the owner's manual for the location of the defrost timer, it could be bad. The thermostat needs to be checked and set so that it is at a reasonable level. One last thing to check would be the condensate drain. Make sure the drain is not plugged or the line is not plugged. Good luck.
Jul 31, 2009 | Amana ARB2557CW / ARB2557CB / ARB2557CC...
Amana SR520SSide by side fridge freezer: How do I take off the dm
CLICK HERE for a PDF version of your use and care manual.
CLICK HERE for Installation Manual.
Page 3 of the installation Manual has the instructions on removing the doors.
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
Jun 25, 2009 | Amana 22.6 cu. ft. Side-By-Side...
Where is the filter on a Amana SQD23VW
CLICK HERE for all the blowout diagrams of your fridge.
CLICK HERE for your Owner's Manual in PDF format.
CLICK HERE for your Installation Instructions.
The water filter is found in rear right corner of refrigerator section. Twist cartridge counterclockwise 1/4 turn and pull down to remove.
Some fridge model levels did not have a filter and you will find a bypass cartridge there instead.
May 06, 2009 | Amana 22.6 cu. ft. Side-By-Side...
Refrigerators Logo
64 people viewed this question
Top Amana Refrigerators Experts
Steve Allison
Steve Allison
Carmen Mikulic
Marvin
Marvin
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
