Question about IBM NetVista A40i (2251VAU) PC Desktop
Reboots itself within minutes
I thought I had a software issue that was causing my computer to continually reboot itself and I couldn't stay on long enough to get rid of any programs. It did this after I installed AOL 9.0. So, I finally restored the hard drive and started over. Needless to say, software wasn't the problem. My computer now comes on to the windows me desktop and then reboots itself. Help!
  • Koalakid Nov 29, 2007
    Thanks for the reply.....however, I have tried the safe mode and get that screen up, click on settings and the computer goes back into rebooting itself. I can never get to the add and remove programs area. However, it shouldn't be on there as I did a complete recovery of the hard drive when I wrote the question.
    G
    Sergeant:
  • 324 Answers
I think that if you can boot up in safe mode you can slow things down enough to do something. If you can get there, you can stop the rebooting by going into "Control Panel", click on "System", click on the "Advanced" tab, click on the "Settings" box and uncheck the "Automatically Restart" box.
Then you can go in to "Add or remove programs". If you remove the AOL program, you'll probably be good!
Please let me know how this works for you.
Ron-
Posted on Nov 26, 2007
  • Ron Roske Nov 30, 2007
    Man! This is a strange one...
    Because it does get up to desktop before it starts to reboot, it sure looks like an O/S problem. Sorry that I missed the fact that you said that you had already reloaded the O/S.
    I don't have any solid suggestions for you. Might be something fluky with memory? You could try to reseat the memory modules.
    Don't really like to bring the subject up, but you may have had a motherboard go casters up on you.
    I'd suggest putting an external monitor on it, and disconnect everything but 1 memory module, the keyboard, and the HDD and see what happens. If you still have the same problem, then it's probably the motherboard. If not, then you probably have a bad touch pad, CD reader, PCMCIA card, wireless card or LCD. Can't see any of those causing this symptom, but suppose it's possible.
    The only other thing that I can come up with right now is to completely disconnect absolutely everything from the motherboard and then plug everything back in. If you have a connector that is having problems, that should fix it, maybe. ;o)
    Try those things and let me know. In the meantime,I'll scratch my head and think some more.
    Ron-
It is silent over night bur as soon as the door is opened in the morning the motor kicks in and it starts buzzing. this goes on all day.
NOT SURE THIS IS UR PROBLEM BUT THOUGHT ID SEND IT
Fridge FAN CONTINUALLY STAYS ON OR SHUTS OFF WHEN DOOR IS OPENED:
NORMALLY WHEN THIS HAPPENS U EITHER HAVE A DOOR CONTINUALLY OPEN ISSUE OR A BAD DOOR SEAL LETTING AIR IN AND CAUSING FAN TO OVERWORK ITSELF. ANOTHER CAUSE CAN BE DIRTY COILS AND CONDENSER AND LASTLY NOT TO COMMON IS A SHORT IN THE FAN SYSTEM ITSELF. A MORE PROBABLE CAUSE COULD BE BAD THERMISTORS OR EVEN COLD CONTROL THERMOSTAT ( WHEN THE THERMISTORS OR THERMOSTAT DO NOT GET/GIVE A PROPER READING, THEY CAN CAUSE THE FAN TO CONTINUE TO OPERATE AS THEY FAIL TO RECOGNIZE OR REGULATE THE PROPER TEMPERATURE
Apr 09, 2015 | Refrigerators
Since installing Windows XP, replacing Windows 2000 on my PC I get an error message on start up that there is an issue with my CD driver and that this may cause instability. The drive works OK and no...
the message is likely association with an item listed in the MSCONFIG startup group. The message itself seems harmless and if the system is running to you satisfaction, nothing has to be done.
If you want to try and get rid of the error, open MSCONFIG, startup tab and uncheck all items and reboot. if the issue is gone on reboot, then one of the items in the startup group is the issue, go back to MSCONFIG, re-check the top half, reboot see if the error comes back. Continue rechecking half the remaining items till you isolate the section the issue is being generated from, then unchecking just 1/2 of that section get doing halves till you isolate the 1 entry that is the issue (Usually can be done in 7 to 8 reboots) once determined, leave that item unchecked and if you have no further issues, you are done.
IF leaving that item unchecked causes another issue, the see if there is an updated driver for that item
Jan 16, 2011 | Computers & Internet
Reboot my pc
Thank you for your question.
I will presume that the computer has frozen and is not responding to keyboard/mouse commands. In this instance holding down the power button until the Operating System shuts itself down is acceptable. This is not the ongoing solution and should not be used continuously as it will corrupt the Operating System. If the computer is freezing continuously, there is another problem that needs to be identified and corrected. Installing new hardware and software can cause freezing and in Windows 7 not installing compatible software does cause issues.
If this is not the case, please repost with some more information and we will attempt to assist you further.
Kind regards
Nov 22, 2010 | Microsoft Windows Vista Ultimate Edition
When I start my computer it shuts down and reboots about 4 times before it will finally start properly
Hello
A computer that constantly reboots can have one of several issues, and can be hard to troubleshoot if it will not stay on. Viruses and spyware can cause the computer to reboot continually, but hardware failure or power issues can also be the root of the problem. There several ways to approach the troubleshooting process.
Hardware failure can cause a never-ending reboot cycle; eliminate the most common causes first. Replace memory chips one at a time to rule out a bad stick of RAM. If the memory checks out, boot from the Windows CD and access the Recovery Console. Run chkdsk /R at the command prompt to check for problems with the hard drive. Remove any optional cards that were added in to the computer (such as a sound or network card) to eliminate them as the cause.
Press the F8 key while the computer is starting up to access the advanced start-up options. Select "Last Known Good Configuration," and press Enter. If that does not work press F8 again, and select "Safe Mode" this time. If you are able to access Windows in Safe Mode, disable the option to automatically restart Windows after system errors by right-clicking on the My Computer icon and selecting "Properties." On the Advanced tab, click the "Settings" button under "Startup and Recovery" and clear the check box labeled "Automatically restart." This will allow you to restart the computer without getting stuck in the reboot cycle. Ensure that your antivirus and antispyware software is up-to-date, and perform complete scans for any infections. Remove any newly installed software that may be incompatible with Windows, and update drivers for your hardware.
Replace the power cord to the computer, replace the power strip it's plugged in to, and try a different outlet. If nothing else helps, try a new power supply. Be sure to purchase one with enough power for your computer: use a high-performance power supply for a gaming computer or a lower-performance power supply for a regular workstation.
Nov 13, 2010 | Microsoft Windows XP Home Edition
My Gateway GT4010 PC keeps rebooting itself before
Try replacing the hard drive cable. If that doesn't fix the problem, then you may have bad RAM, bad motherboard or a bad power supply. Sounds like a hardware issue and not software. try booting your computer in safe mode since it doesn't load all the device drivers. If it still reboots then you'll have to keep swapping parts and booting up the computer to isolate the problem.
Oct 06, 2009 | Gateway GT4010 (RBGT4010) PC Desktop
EMachine T3120 keeps rebooting
You can manually download drivers from eMachine's site: http://www.emachines.com/support/product_support.html
The operating system, you'll need a disk...and product key.
Sounds like a reformat may be your only option at this point. How far will the machine boot up? Can you boot up in safe mode?
Feb 07, 2009 | E-Machines eMachines Desktop PC
Computer crash and restart
Windows restarts without warning
Cause:
This issue could be caused by any of the below possibilities.
Software issue or error.
Hardware issue or error.
Heat related issue.
Computer virus.
Issue with operating system.
Answer:
Errors generated by software programs can cause a computer to reboot unexpectedly or without warning. If you are running Windows XP see the below section "For Windows XP users" before continuing.
If you are not running Windows XP or following the below steps still cause your computer to reboot without warning. Boot your computer into Safe Mode, and let the computer run in Safe Mode.
If the computer is still rebooting in Safe Mode the issue is likely not software related but something else, skip to the next section. If the computer is not rebooting in Safe Mode it is likely you have software related issue. We would recommend you run through the basic troubleshooting section for your operating system.
Windows XP is designed to automatically reboot each time an error occurs such as a BSoD. Although this may be nice for errors that do not occur often, users who have a re-occurring error may wish to identify the error to troubleshoot it. Below are the steps on how this feature can be disabled and enabled in Windows XP.
From the desktop right-click on My Computer.
Click the Properties option.
In the System Properties window click the Advanced tab.
In Advanced click the Settings button under Startup and Recovery.
In the Startup and Recovery window uncheck the Automatically restart check box.
Click Ok.
Now if the computer generates and error it should not automatically restart and enable you to display any errors your computer may be experiencing.
Any failing hardware component in your computer could cause your computer to unexpectedly generate an error and/or reboot without warning. If you have recently attempted to add a new hardware device, remove that device to make sure it is not causing your issues.
Make sure you are not encountering any hardware conflicts by viewing Device Manager for errors.
New drivers can also cause this issue, if you have recently performed any hardware driver updates you may wish to try an earlier version of the drivers.
If you have updated drivers and removed any hardware that could be causing this issue and continue to experience random reboots, it's possible that the memory is bad in the computer.
Finally, hardware devices that are not installed properly in the computer can also cause random reboots. Make sure all the cables and expansion cards are connected properly to the computer. The best way to determine this is to disconnect and reconnect all cables and expansion cards.
Computer virus
Computer viruses such as the blaster virus are written to reboot your computer without warning. Usually these viruses will make the computer reboot ever 5, 10, 15 or 30 minutes after the computer has booted.
If you believe your computer may be infected with a virus or are uncertain if your computer is infected with a virus make sure your virus scanner definitions are up to date.
Heat related issue
Many computer today are designed to turn off or automatically reboot if the computer, processor, or other device in your computer gets to hot. If you have heard any abnormal noises coming from your computer recently such as a high squealing this could indicate a fan may be failing in your computer.
You can first start by verifying the fan on the power supply is working by examining the back of the computer and seeing if the fan is moving and moving smoothly. For all other fans in the computer you will need to either open the computer and make sure the fan are working (processor fan and case fan) and/or if your BIOS monitors the RPM of the fans enter BIOS and make sure the BIOS does not report any errors.
Users may also be able to determine how hot their computer is by onboard thermal sensors, if your computer comes equipped with these sensors make sure your CPU is not running to hot.
If after following each of the above recommendations your computer still continues to reboot it is likely that you are experiencing a Microsoft Windows operating system related issue that cannot be explained. To help make sure this is the case please try the below steps.
Reboot the computer and enter CMOS setup as the computer is booting.
After you have loaded the computer in CMOS setup let the computer sit.
If the computer does not reboot while letting the computer sit in CMOS it is likely that you are in fact experiencing an issue with Microsoft Windows and it is recommend that if you have followed all of the above recommendations that you reinstall your version of Microsoft Windows.
Jan 28, 2009 | Computers & Internet
Rebooting on Dell D600 Latitude
Heat related issue.
Computer virus.
Click Ok.
Make sure you are not encountering any hardware conflicts by viewing Device Manager for errors. Additional information about Device Manager can be found on our Device Manager page.
New drivers can also cause this issue, if you have recently performed any hardware driver updates you may wish to try an earlier version of the drivers. Additional information and help with computer drivers can be found on our drivers page.
Computer virus
Heat related issue
Nov 19, 2008 | Dell Dimension 9200 PC Desktop
HP PAVILION LAPTOP SHUTS OFF AND REBOOTS AFTER A FEW MINUTES
Heat related issue.
Computer virus.
Click Ok.
Computer virus
Heat related issue
Nov 12, 2008 | Computers & Internet
Monitor issues.
plz boot in safe mood and uninstall the display driver and reboot normally.if your problem persist then download the latest display driver from the net and install it.
Apr 01, 2008 | Dell Latitude C610 Notebook
IBM NetVista A40i (2251VAU) PC Desktop Logo
115 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
