Question about Sony PlayStation 2 (PS2) Console
PS2 Clicking Noise Read Disc Error
I've tried the Q-Tip thingy with the glass cleaner because I have the mini PS2 and it was filthy but I cleaned it anyway and it still makes the same clicking noise. Any DVD or PS 2 disc with the DVD symbol will not work at all. It only reads PS1 and music discs. I've about had it with the machine and have almost no chioce but to buy a new one.
    Scholar:
  • 116 Answers
I had the same problem and I found a link that helped me, so try it! But make certain that you really want this thing fixed, because if you send it out they will probably do the same, may cost you alot more. Here all you need is patience, a litte time, and a clean area to work in! Here is the link good Luck:http://www.bolthole.com/ffxi/dvdclean.html It worked for me! I have no problems now!
Posted on Nov 26, 2007
My ps2 is getting a disc read error. It is the console, not the disc. How do I fix this? I've heard that you can clean the laser reader with alcohol wipes. Is this advisable, and if so, how should...
If it's the original, fat PS2 go here:
http://www.slideshare.net/Bravo77/ps2-repair-guide
If it's the newer, slimmer PS2.
To clean the laser lens, do the following:
Dip a Q-tip in rubbing alcohol (not dripping) gently place the q-tip on to the lens and gently twirl the q-tip.
Use the other end of the q-tip to gently dry the lens.
Hope this helps :)
Jul 16, 2011 | Sony PlayStation 2 (PS2) Console
Ps2 is unable to read disc, how do I reset the factory settings. I am hoping if I reset it that it will work
Please watch this video I have attached. The disc read error on the ps2 is a hardware problem, not something that can be fixed by a reset.Good luck!
Jul 12, 2010 | Sony PlayStation 2 (PS2) Console
Whatever ps2 game disk inserted,the ps2 won't just read disc.
hey! calm down boy, now here, just listen and follow or do what i said exactly ok, now, go to your mom and ask some money to buy the head cleaner or disc drive cleaner. do you know what is that? its a cd software that you are going to insert to the PS2 drive and it clean will clean the eye of your ps2 drive, so that it can read the cd. ok. you can buy this cd cleaner on the radioshock. ok
Aug 30, 2009 | Sony PlayStation 2 (PS2) Console
Ps2 format disc
Dirty laser / or a damaged disk.
Open it up and use a Q-tip soked in windex
wipe , then try it again should fix the red screen of death.
Jun 04, 2009 | Sony PlayStation 2 Slimline Console
Goes to Startup Screen when I put a game!
try cleaning the lens. for a slimline PS2, try a Q-tip with a little bit of alcohol on it and lightly touch the lens. gently TWIRL the Q-tip. use the other end of the Q-tip to dry the lens, again, gently twirl the Q-tip. or you could use a laser lens cleaner (see below). for a fat PS2, either use a laser lens cleaner specifically for video game systems (Best Buy, etc.) or go here and go to the very end. www.powerfulguides.com/ps2 hope this helps :D
May 30, 2009 | Sony PlayStation 2 (PS2) Console
Sony ps2 read disc error problem
Now this is strange PS2 hangs up..............!!!wHich pS2 u have.........???slim or the old fat one.........???As far as disc read errors are there, u should clean ur lens by using some lens cleaner CD or do it manually[for fat one] urself it not a big deal........becarefull while opening the cover....clean the dust on lens with the tissue or any other light material......the problem can also b with ur disc change that also...........
Sep 17, 2008 | Sony PlayStation 2 (PS2) Console
Disc read error
You will ne4ed to clean up the PS2. open it up and clean the laser lens with alcohol on a cotton swab. If it is the Slim Ps2 model you should not use Alcohol. Use A glass Cleaner like windex on the slim. Sometimes the magnet gets week and you need to add some magnetism to help improve the spindle grip on the Game disc. Cut up a refridgerator magnet and place it in the white cap thatt clamps the Game disc in the cd player.
Jan 06, 2008 | Sony PlayStation 2 (PS2) Console
Ps2 ERROR!
Open the case up and remove the CD cover. Be careful of the Reset Eject button cable when you remove the top cover. Best to Lift the cover from the rear slightly, pull it forward, then roll it over from left to right and lay it upside down with the ribbon cable still attached.
Remove the CD cover. Clean the lens of the laser with a q-tip lightly dampened with glass cleaner. use the dry end of the Q-tip to dry it. Get a Can of Air from Radio Shck and with little force, blow out from under the lens. Clean off the Worm gear that moves the laser back and forth. make sure no lint or hair is wrapped around the motor that spins the disc. Use the can of air to Blow out the Fan of dust. Test it out, good luck.
If you still have trouble, you can cantact a repair shop by Clicking on "Repair Directory" at the bottom of this page. Choose "Video Game Consoles" on the next screen.
Nov 28, 2007 | Sony PlayStation 2 Slimline Console
Disc reading error
Open the Case.
Clean the lens with Q-tip and Alcohol. This is only if you have the SCPH-30000 through 5000X models. If you have the Slim Ps2 do not use Alcohol on the lens. Use Glass cleaner instead.
Nov 25, 2007 | Sony PlayStation 2 (PS2) Console
Disc reading sound ps2 slim
Check around where the laser connects to the worm gear that moves it up and down. You may have some lint wrapped around the worm gear. Also check the disc spindle motor for Lint trapped under it. It could be your laser lens getting dirty.
Clean the Slims lens with a Q-tip and Window Glass Cleaner.
  1. Lightly Dampen one of the tips of the Q-tip with Glass Cleaner
  2. Swab the laser lens with the dampened Q-tip.
  3. Clean and dry of the laser lens with the dry tip of the Q-tip
Good luck
Nov 08, 2007 | Sony PlayStation 2 (PS2) Console
Sony PlayStation 2 (PS2) Console Logo
243 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
