we have a zebra lp2844 and it cuts the labels off on the righthand side where the bar code is cut off. is there a way to center the label ? any help would be apreciated! thanks.
Turn off the printer and place your finger on the green feed button. With the button depressed, turn the printer back on. Let the light flash (ONLY!) four times and release the button. Printer will cycle through 2-3 labels. Press the feed button one more time. You've just set the printer back to factory default which should use the top of form and label dimensions to print in center. If not....I need more info - what type of software are you using?
Was this helpful?
Yes
No
Popular Solutions for Zebra Eltron TLP 2844 Thermal
I am not able to print properly jewellery label (tag) in zebra tlp2844. there are 2 tags in each...
(More)
I am not able to print properly jewellery label (tag) in zebra tlp2844. there are 2 tags in each label. First one print all right, but next ones are not on the tag, printer leaves some gap. i have removed gaps between labels as well in printer properties, but still nothing. please if you can let me know how can i calibrate jewellery tag in tlp2844 Thanks
I use it to print small jewelery tags. It prints the vertical 90o bar codes fine but when I try to...
(More)
I use it to print small jewelery tags. It prints the vertical 90o bar codes fine but when I try to print the same bar code horizontally it does not print all the lines. Thought I had printer head problem but the same happens with the new one.
