The model is Nv 1800q innov-'is The presser foot has been tightened ,machine has been retreaded ,meddle changed numerous times , it keeps stopping randomly
SOURCE: Doesn't sew
Hi emnsam....please update your post with the complete Model Number in it's entirety and I will be able to advise you.
SOURCE: Babylock ellure safety device
I have the same problem, I have done what the book says but no luck yet. Have you figured out what happened? And do the experts really check the questions? Cause I asked a question awhile ago, and no answers. Help!
SOURCE: Brother 270D Jams when sewing anything
You might have thread caught in the take-up lever linkage and it has soaked up all the oil my recommendation would be take it to your local dealer
SOURCE: the safety device has been activated
Turn off the power supply and open the needle plate.
Remove the bobbin and bobbin case.
Clean the shuttle and surrounding area from any lint or thread that may have accumulated during use.
If the problem continues, the machine will need to be serviced by a Brother dealer.
SOURCE: presser foot stopped working I turned
Did you connect your machine then press the foot control before you lowered you presser foot? I have a CS6000 and that is what E1 means on my machine. You did not put your model number in so I don't know. You can look in your manual or go online to www.brother-usa.com and look it up for your machine. Try unplugging and plugging it in again, but put your presser foot down then step on your foot pedal.
