Question about Homelite Garden
L pulled starter cord on my Homelite line trimmerHLT25cs, it would not engage and I heard a noise as I pulled . there was no resistance on the pull, but it recoiled just fine. what do I need to do?
  • Homelite Master
  • 3,042 Answers
Try service manual via http://www.manualsonline.com
For your machine. Depending on age the "clutch" is not engaging on the shaft for some reason. It may be that some screws have come loose or missing. You may need to buy a new recoil mechanism.
Posted on Oct 28, 2018
SOURCE:
boscia
  • 163 Answers
SOURCE: Ryobi Line trimmer
you have to remove the starter housing, inside will be 2 knobs that spring out when the cord is pulled that contact the flywheel cap of the motor and rotates the crank. check if they are missing or damaged and that they ejecting when the cord is pulled. if not; replace.
Posted on Nov 29, 2008
steve_lima
  • 181 Answers
SOURCE: Pull cord on weedeater wont recoil
sounds like the spring is broken itself.there should be a hook at one end and a loop at the other end.the hook usualy breaks off but the spring looks good.replace the spring with part number..4140 190 0600 ....that is the stihl part number.let me know if this helped you...if not give me a quick mail and i'll try to help some more......
Posted on Mar 13, 2009
jj505
  • 195 Answers
SOURCE: Replace starter pull cord
http://www.google.com/search?hl=en&rlz=1T4GGLR_enUS311US311&q=homelite+yard+broom+ut08110%2Creplace+pull+start+rope&btnG=Search
This may guide you
Posted on Mar 16, 2009
  • 376 Answers
SOURCE: starter cord not recoiling
To get to the starter rewind, you have to pull off the clutch hub and clutch. Without the proper tools, it would be best to take it to a shop. Dwain
Posted on May 26, 2009
steve_lima
  • 181 Answers
SOURCE: Starter on trimmer wont retract
i'm sorry to tell you this, you have to take take the hole recoil apart.either the spring is broken or the dog that holes the spring is not engaged.to fix it you have to take it apart.restring the rope,make sure the dog is catching the spring,rotate the recoil rotor to tension the spring,retie the handle and reinstall the recoil as an assembly.hope this helps,let me know if you have any questions...........
Posted on Jun 02, 2009
The manual recoil starter I pulled starter slowly two or three times and then cord was loose no resistance what is the problem?
Sounds like the starter drive is jammed. Look for a large cog azt the back of the starter cord on the motor, manually push it in the opposite direction to the spin created when the cord is pulled.
Dec 29, 2015 | Garden
Tanaka tht 2100-very difficult to start. Pull cord is is either too loose when pulled or it is jumpy, meeting with a bit of resistance?
i think it sounds like the motor is going i had a chainsaw and it did the same thing after a while the motor went and the chainsaw was no good anymore so you mite want to take it to a dealer that deals with your grass trimmer
Sep 03, 2012 | Tanaka Commercial Grade "Inspire" Design...
I have been trying to turn on my chain saw. Ive pulled the handle back by the trigger gave a few pull on the rope. then i pushed the button in on the side also the push the button back in by the trigger...
The chainbrake should be activated when starting the chain saw. Activate the chain brakeby pushing the front hand guard forwards.b>Cold engine Start position, 1: Set the start/stop switch in the choke position by pulling thered control outward - upward.Decompression valve: Press the valve to reduce the pressure in the cylinder and makestarting easier. Once the machine has started the valve will automaticallyreturn to its original setting.Air purge: Press the air purge diaphragm repeatedly until fuel fills thediaphragm (at least 6 times). The diaphragm need not be completely filled.Grip the front handle with yourleft hand. Hold the chain saw on the ground by placing your right foot throughthe rear handle.Pull the starter handle, 4: Pull the starter handle with your right hand and pull out thestarter cord slowly until you feel a resistance (as the starter pawls engage)then pull firmly and rapidly until the engine fires.Push down the red choke control: As soon as the engine fires which can be heard through a"puff" sound, push down on the red choke control.Pull the starter handle (6): Keep on pulling the cord powerfully until the engine starts.
Nov 18, 2010 | Husqvarna 450 e-series 18" Chain Saw
My Homelite chainsaw 33cc zr10926 won't engage when the cord is pulled.
Remove the starter mechanism from the engine and examine the 'dogs' which engage the flywheel. They either damaged or their pivots are frozen with dirt and other debris. Hope this helps!
Oct 16, 2010 | Homelite Garden
When pulling startercord there is a clanging noise andthe achain adjuster screw works itself loose
Remove the bar and chain--start the engine--do you get the same noise? If so, then remove the entire starter mechanism--look for loose/damaged parts, especially anything related to the components that engage the flywheel/crankshaft when the cord is pulled. Normally, the chain adjuster screw is important only while adjusting the chain--once the bar clamp screws/nuts are tightened, the adjustment screw is tightened so that it won't back off. Hope this helps!
May 07, 2010 | Homelite Garden
Won't crank, thing next to spark plug keeps popping up
Jerry is correct the compression release is ajdacent to the spark plug. If it pops the saw fired and the release closed (what it is supposed to do).
Read page 22 here:
http://weborder.husqvarna.com/order_static/doc/HOUS/HOUS2009/HOUS2009_1151382-49.pdf
Excerpt follows: "Pull the starter handle (D): Pull the starter handle with your right hand and pull out the starter cord slowly until you feel a resistance (as the starter pawls engage) then pull firmly and rapidly until the engine fires. Push in the choke control as soon as the engine fires which can be heard through a "puff" sound. Keep on pulling the cord powerfully until the engine starts."
Continuing with the choke closed causes flooding. Please read the "Warm Engine" too it is slightly different.
HusqvarnaUSA.com
http://www.husqvarna.com/us/homeowner/support/download-manuals/
Enter the 3 digit model number (no XPs, Es, just the numbers)
Serial number decode – useful when downloading IPLs and Manuals
06 1500198
06 = year produced – 2006 (single digit before 2000)
15 = week produced - March
00198 = 198th unit Husky produced that week.
HTH
Lou
Jan 09, 2010 | Husqvarna , No.455 Rancher, 20" Gas -...
Ryobi Line trimmer
Jul 24, 2008 | Ryobi 15" Electric Factory Reconditioned...
Garden Logo
158 people viewed this question
Top Homelite Garden Experts
roeb
Jay Finke
Jay Finke
Randy Schumann
Randy Schumann
Are you a Homelite Garden Expert? Answer questions, earn points and help others
