Question about Maytag MZD2766GES Side by Side Refrigerator
Refrigerator help I need help with connecting the water lines one is already hooked up but I'm not sure where the other one is to be hooked up
  • gude Apr 08, 2008
    The refrigerator was moved to a new home and during the process it seems that the water line to the water dispenser was disconnected (appears to be a joint or connection at the bottom of the refrigerator under the freezer door) via some sort of connector? I need to find a diagram of this lie and the connector part / model number so I can buy another one.
Freezer ok refrigerator not cold
Posted on Mar 30, 2008
  • 833 Answers
You should only need one water line to feed the water and ice maker with domestic water.
Posted on Jan 03, 2008
Water comes out real slow from dispenser. we put by pass in and still slow.
When you say you put a bypass in, are you referring to a bypass for a water filter? Make sure there isn't a filter that was already in the line outside the refrigerator or, if that's what was bypassed, make sure there isn't another filter in the refrigerator.
If you're positive that the filter isn't the issue you may need to disconnect the water line and check for debris in the connection to the refrigerator, then confirm you have good water pressure to the fridge.
Nov 21, 2016 | Refrigerators
HOW TO HOOK UP AND START THE ICE MAKER ON JSI_23
Good Morning Le Morrer,
I see that you are trying to hook up and start the ice maker on your Frigidaire refrigerator, model# FRS3R5EMB.
To connect Water supply Line to ice Maker inlet valve:
1 Disconnect your refrigerator from the electric power source.
2 Place the end of water supply line into sink or bucket. Turn ON water supply and flush supply line until water is clear. Turn OFF water supply at shutoff valve.
3 Remove plastic cap from water valve inlet and discard cap.
4 If you use copper tubing - Slide brass compression nut, then ferrule (sleeve) onto water supply line. Push water supply line into water valve inlet as far as it will go (1/4 inch/6.4mm). Slide ferrule (sleeve) into valve inlet and finger tighten compression nut onto valve. Tighten another half turn with a wrench; DO NOT over tighten.
If you use stainless steel tubing - The nut and ferrule are already assembled on the tubing. Slide compression nut onto valve inlet and finger tighten compression nut onto valve. Tighten another half turn with a wrench; DO NOT over tighten.
5 With steel clamp and screw, secure water supply line (copper tubing only) to rear panel of refrigerator as shown.
6 Coil excess water supply line (copper tubing only) about 2 and 1/2 turns behind refrigerator and arrange coils so they do not vibrate or wear against any other surface.
7 Turn ON the water supply at shutoff valve and tighten any connections that leak.
8 Reconnect your refrigerator to electrical power source.
9 To turn the ice maker on, lower wire signal arm (side mounted) or set the ice maker's ON/Off power switch to the "I" position (rear mounted).
After connecting the water supply, you will need to prime the water supply system.
To Prime The Water Supply System:
1 Begin filling the tank by pressing and holding a drinking glass against the water dispenser paddle.
2 Keep the glass in this position until water comes out of the dispenser. There will be noticeable spurts and sputters as the system pushes air out through the system and dispenser nozzle. This is normal. This may take about 1 and 1/2 minutes.
3 Continue dispensing water for about 3 minutes to flush the system of any air and impurities. Empty the glass as needed.
The water dispenser has a built-in device that shuts off the water flow after 3 minutes of continuous use. To reset this shutoff device, simply release the dispenser paddle. Hope this is helpful.
-Best Regards-
WP
Mar 14, 2014 | Frigidaire FRS3R5EMB Side by Side...
How to Change ice filter in 532 sub zero my ice taste bad
The answer to your question is yes. First go to home depot or lowes and tell them you want an in line water filter for a refridgerator and you want that filter to have the brass or copper threaded connections already on the filter. While your there pick up a couple of stainless steel water lines. The fittings for the filter are going to be 1/4 inch fittings, so be sure to get the right size lines. Once your back home, pull the machine away from the wall, unplug it, jsut for safety, and turn the water off. The next thing you want to do is disconnect the old water line from the wall and from the water valve on the fridge. Before you hook up the filter make sure you note the water flow direction that should be on the side tellling you which way it should pass throught the filter. Hook up the line that will go from the wall to the filter but don't connect the valve yet. Once you got it connected to the wall get a bucket and place the line that goes to the valve in it and turn the water on. This way the filter is flushed before you hook it up to speed up the process of getting that bad water out. Ok, flush a few gallons, then hook the line to the valve, plug in the machine and your done. Allow a few cycles of ice to pass before you notice the difference. Good luck
Jun 16, 2012 | Refrigerators
Ice Smell/Taste funny
Apr 27, 2012 | GE GTH21SCXSS Stainless Steel (21 cu ft)...
I just bought a used kenmore elite side by side refrigerator and hooked up the water line to the back of the fridge. My question is where does the long water line the goes to the fridge and comes back...
Where you hook the house water line is to the water inlet valve which is a one in two out solonoid controlled valve. One side goes to the water dispenser in the door and the other hooks to the ice maker connection.
So I suspect the long water line you are talking about has had the lines switched at the valve and needs reversed. The long line probably goes up the back of the unit and connects to the ice maker. The one for the water dispenser should hook to the water chiller resevoir and then to the water dispenser.
Sep 14, 2011 | Kenmore Side by Side Refrigerator
Hooking up water line to LG LRSC26920TT - water runs great through line, but once connected to fridge, no water runs through line in fridge - no water comes out when trying to fill a glass. No water...
dissconnect water line coupling behind lower kick plate under door. push water dispenser; and sell if water flows out line. keep a towel handy. it there is water; then, the problem is in the door itself. of course, make sure the water solenioids are working.
Apr 17, 2010 | LG LRSC26925 Side by Side Refrigerator
Msd2756geb water tube coming out door not hooked up?
Check diameter of pipe. Suspect its quarter inch. You will then probably need to purchase e.g. from ebay etc a 1/4'' to 3/4'' adapter which will allow you to connect your fridge pipe to a typical water pipe connector (i.e. similar connecting a washing machine), assuming you already have an available water conenction in the lcoation of the fridge!
Jun 16, 2009 | Maytag MSD2756G Side by Side Refrigerator
Plastic Water Line Coiled Inside the Refrigerator
The coiled line is used for chilling the cold water dispenser. Most of the time they are hidden from view,
Mar 16, 2017 | Frigidaire FRS26R4A Side by Side...
How to install a water line to a Samsung Refrigerator?
I have a slightly different refrigerator but the same problem. It says white line, but the white line is attached to the fridge on both ends and the blue line is not. Also the instructions do not actually look like the refrigerator so that is no help. No probelm installing a filter or the waterline to my water, but now I can't get it into the fridge.
Jan 11, 2009 | Samsung RB2155 Bottom Freezer Refrigerator
How to hook up Ice & Water dispenser on freezer door
The water valve is on the back of the refrigerator. The water line connects directly to that valve. If there is no line available then you will need to run one from a cold water line in the plumbing using a drill type (1/4") saddle valve on that pipe. Hope this helps. If you need more instruction let me know!
Oct 06, 2007 | Refrigerators
Maytag MZD2766GES Side by Side Refrigerator Logo
Top Maytag Refrigerators Experts
John Tripp
John Tripp
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
