Question about Maxtor Hard Drive
Problem maxtor hard drive
Got a 80 gig hard drive. when i go to format it shows 33 gig, wont show all 80 gigs. what can i do, is ther a speacial drver?
  • 482 Answers
Re: problem maxtor hard drive
Its the format, anyhing over a gig has the new format
Posted on Nov 26, 2007
  • 116 Answers
What type of Computer are you installing this 80g drive on? How old is it? I need to know some specifics, because in older machines the BIOS are not setup to recognize large capacity HD, in addition you may have recieved a bad Drive. Please advise! I may have an answer for you!
0 characters
3 Points
Unable to access space on Lacie remote drive
The easiest way will be to format the disk drive. Highlight the icon, right click and format.
Feb 07, 2010 | LaCie (300770) 250 GB Hard Drive
80 gig maxtor not reconized in computer bios cmos
check the cable & more better way use duel usb cable which occupy 2 usb & i Normal Hdd connector
Dec 05, 2009 | Maxtor Personal Storage 3100 (M01B080) 80...
I have a motherboard that has only has one ide conncetions
what you should do is make the 300 gig as second drive and your primary drive is the 80 gig so that you can view and back-up the contents inside it. If you going to install a new copy of Operating system that would be in the 80 gig so that you don't need to format your 300 gig and make it as second drive. Hope this could help you..Thanks..
Oct 24, 2009 | Hard Drives
Mator 500 gig (one touch) 4 external hard drive & error 80070571
have you tried formating the h/d it will solve the error msg
Mar 16, 2009 | Maxtor Hard Drive
80 gig maxtor
change hard board or
change your cables (date & power)
Oct 27, 2008 | Maxtor Hard Drive
It appears it is not being recognized and mounted. Try running the add new hardware wizard if it isn't in your device manager already.
Feb 12, 2008 | Maxtor OneTouch II external hard drive...
160 gb hard drive
try downloading any program that manages disks (partition magic for example ) and see if all the space appears in that program, if so assign to that space a drive letter and format it .... (with the program that u will use )
Jan 16, 2008 | Maxtor Hard Drive
Format my maxtor
do you have a start up floppy for this drive? If not you can down load it from their web site. set partion. go to fdisk. format c: Done, you need windows disk after that, install
Nov 26, 2007 | Maxtor Hard Drive
Maxtor Hard Drive Logo
118 people viewed this question
Top Maxtor Hard Drives Experts
Brian Sullivan
Brian Sullivan
Mark Taylor
Mark Taylor
Are you a Maxtor Hard Drive Expert? Answer questions, earn points and help others
