Question about Jensen VM9510 Car DVD Player
Jensen uv8 no pic and very noisy when loading
I am having trouble with the wiring, tried to ground the pink wire and even use a toggle switch in the connection for switching off and on, still no pic and the dvd player won't load the dvd. it makes loud noises in attempting to load, is it possible that the unit it bad and should i do anything with the green/white wire or just leave that out.
No, it is not your laser, the jensens have a little trick to making them work, after you put the toggle switch in, you need to place it in the on position, turn it off and back on 5 times in 5 seconds, one flip per second, then the unit will start to play video, after you turn it on for the fith time. you should end in the on position. jensen does this so that you can not just ground the wire to get it to work.
Posted on Dec 05, 2007
  • 709 Answers
i sounds like your Laser is not riding up and down sled freely. Loud noises coming from DVD drive always indicate Sled trouble.
Posted on Nov 30, 2007
Emergency parking wire for jensen vm9311ts
your parking brake wire from radio is pink .
1 take a toggle switch 12 volt dc and 20 amps
2 take the pink wire attach the wire to the top terminal of the toggle switch
3 take the bottom terminal and attach a black wire to it and ground the other side of wire you must have a good ground ...
then once this is done test the switch turn on dvd it a video and flip the switch up and down a couple of time to simulate the parking brake and the video should work ...
if this doesnt work email me and ill give you the relay diagram to connect a relay inline to activate video but im pretty sure it will ... go here to my online store and email me from contacts
Dec 28, 2010 | Jensen Car Audio & Video
Can't find Jensen UV10 e-brake bypass code.
Ok what you gotta do is connect the pink e-brake wire with the black wire that is already connected to the radio as the grounding.
UV10 Works 100%!!!!
Greetings from Montenegro
Jan 28, 2010 | Jensen Car Audio & Video
How do i get my phaser linear uv8 to come on.
Check to make sure you are connecting Power (+) to positive (red) and ground (-) negative (black).
Jun 30, 2009 | Jensen VM9510 Car DVD Player
Jensens UV9 By pass the brake
hook up the ground with the pink and when you are in am/fm mode hit the dvd set up button on the remote, input the no. 5, 4, 3, 2, 1, and 0 make sure it beeps after every no. has been pressed. then it should bring up the hidden menu select the hammer option and turn on the brake bypass option. your done.
i took this from the uv8 brake bypass. it works on the uv9.
Nov 12, 2008 | Car Audio & Video
Product jensen uv8 nov. 2007 model in a trooper 1996 auto
The pink wire in most instances is the DVD's sensor that the vehicle is not in motion and is parked. It then allows the DVD player to display the movie not the warning message nor the blue screen.
Your description " wire on a bolt attached to the body..." indicates that said wire is constantly grounded. The DVD then cannot sense that the vehicle was parked. What this tell us is that the pink wire must first have a +12VDC before it is grounded. This changeover from + to 0 is the trigger. What is required is to have a single pole double throw switch. One end terminal is wired to ACC B+12 while the other to ground with the center terminal to the pink wire. Moving the switch from position OFF to ON (+12 to GND) simulates the parking brakes condition and will enable DVD playback.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Jun 02, 2008 | Jensen VM9510 Car DVD Player
Phase linear uv8 parking brake problem
for the uv8 to bypass the parking brake to watch dvds you have to take the pink wire and put one end to one of the screws on a two screw toggle switch connect the other end of the pink wire to the other screw and connect that to the black ground wire
Mar 12, 2008 | Phase Linear UDV9010 Car DVD Player
turn on the player, start the radio option, go into the setup menu, tap the language tab, ON THE REMOTE press "stop, stop, 5,4,3,2,1" This will bring up the secret menu, you do not need to connect the pink wire
Mar 10, 2008 | Audiovox VM9512 Car DVD Player
Phase Linear UV8
go to setup hit 543210 but hold 0 then turn the bake override on and then hit the X
Dec 11, 2007 | Jensen VM9510 Car DVD Player
How can I watch video in my UV8
no wire it to a switch and you have to flip the switch twice and leave on
Dec 10, 2007 | Jensen VM9510 Car DVD Player
Parking Brake wire on Jensen VM9311TS
It may need to see a Positive....not a ground (the brake wire rests at ground and goes positive when the pedal is pressed). but to answer your question, the brake wire for your car is Light Green and is at the brake switch above the pedal.
Sep 19, 2007 | Jensen VM9511TS AM/FM/CD/DVD/SD Player/7"...
Jensen VM9510 Car DVD Player Logo
59 people viewed this question
Top Jensen Car Audio & Video Experts
xxxxxx xxx
Are you a Jensen Car Audio and Video Expert? Answer questions, earn points and help others
