My kodak m753 wont allow the lens to close. shuts off as soon as i turn on.
Try these procedures.
SOURCE: lens error
It could be jammed or when you turn it on, your finger or somthing is in way of it opening all the way.
SOURCE: KODAK M753 LENSE ERROR 122,1,0,0
I had this problem too, my camera just randomly stopped working and shut off. When I tried to turn it on again it said the whole 'lens error' bit and then shut of. The lens looked a bit crocked so I just gently tried to straighten it out and ta-da! Good as new!
SOURCE: lens is stuck
Maybe lens needs adjustment. The info on this page may help. Copy and paste this link for more info.
http://www.fixya.com/PostAnswer.aspx?thid=1841738&prdid=447928&ctgid=67
SOURCE: kodak m753 lens error 101, 1, 0, 0
The problem you describe is frequently the result of dirty/corroded
battery contacts in the camera. Try removing the batteries and
cleaning the inside contacts with a fine wire brush, steel wool, or
fine sandpaper. Remove any residue left from the cleaning, then
replace the batteries. Hopefully all will be well.
If the cleaning doesn't work you might want to check the Kodak troubleshooting guide at:
http://www.kodak.com/global/en/service/repair/troubleshooting/troubleshooting.jhtml?pq-path=6198
