Question about Sub-Zero 632 / S
Icemaker not make ice. - Sub-Zero 632 / S
  • 3 more comments
  • Anonymous Jan 05, 2008
    My icemaker is not making ice.
    Icemaker quit making ice. The icemaker is in the on position. Can hear the motor running but no ice is being made.
  • lmgrego Jan 05, 2008
    Similar issue. The water tube keeps freezing up. I've cleared it with a hair dryer a few times, but it only goes for 1-2 cycles before refreezing.
  • Larry T Apr 13, 2008
    My icemaker stopped making ice after I returned from Florida after three months. I checked and found that water was getting to the water control valve but not up to the ice maker. I replaced the control valve but that did not solve the problem. It still is not getting water uo to the icemaker. Any suggestions?
  • edmedders Feb 03, 2009
    icemaker will not make ice does not appear to get water into the tray.
I have water to the refri but no ice, the refri sit fo a couple years but was running and when it started being used again never did work right and now don't work at all.
Posted on Feb 02, 2009
Not making ice
Posted on Dec 24, 2007
Top ice maker in Samsung RFG298AAPN does not make ice. No water cycles into icemaker. Icemaker has been reset, nothing after 2 days. Should I replace the icemaker or the water valve.
On these models I've noticed that the temperature in the ice maker area warms up due to a ball of ice forming inside the freezer compartment ice maker fan that has vent going to the ice maker. Until it is found whether or not that ball of ice is blocking the vent and fan you won't be able to go to the next step. The switch on the ice maker will test the ice maker by filling it with water and rotating the Forks that dump the ice into the ice bin Appliance 911 Sea Breeze
Aug 31, 2016 | Samsung Refrigerators
Is it OK for ice thickener sensor touch water on ice maker
Yes, it has to touch the water. As the ice builds up the thickness sensor moves up and turns of the refrigeration and turns the heater on.
  • How Icemakers Work ' HowStuffWorks How Icemakers Work. ... we'll look at the cycle an icemaker goes through to make ice. ... Get the best of HowStuffWorks by email. Keep up to date on:
  • How Does The Ice Maker On A Refrigerator Work ... - YouTube
    • 4 MIN
    2012-05-15 · Video embedded · This video provides information on how a refrigerator icemaker works and offers troubleshooting tips ... How Does a Refrigerator Water and Ice Dispenser Work?
  • How Ice makers Work - How Ice Makers Work! Learn How Ice Makers Work, ... How Ice makers Work. The Ice Maker Cycle ' Ice Maker Components ' Cube Size Replacement Ice Makers . They Don't Make
  • How Does an Ice Maker Work? - Refrigerators Here's how your ice maker works. BACK TO . Best Right Now; How To s; Award Winners; How We Test; ... How Does an Ice Maker Work? It's more complicated than ...
  • Refrigerator Icemaker Repair How It Works
    May 12, 2016 | Refrigerators
    Amana model tg21vl stops making ice
    pull on icemaker fingers to force icemaker , check for ice in tube to icemaker and listen for the valve to open , if all checks ok replace icemaker
    Feb 24, 2013 | Refrigerators
    Ice cube tray won't stop making ice.
    This is due to the arm that controls the switch on the icemaker itself either being shorted or froozen in the toggled position. Usually the arm would lift as your ice container becomes full and shut the icemaker off until it reached a level where the switch would then toggle to the make ice position and then start makeing ice again. There are three 1/4" screws that hold the icemaker in place remove these screws unplug the icemaker and then use hot water to dethaw your ice maker for about 2-4 minutes after wards dry the icemaker then try reinstalling the icemaker if the problem persists replace the icemaker itself. If you have any further questions message me back I await your reply.
    Thank you
    Mar 12, 2012 | Refrigerators
    I have a GE Profile refrigerator, Model PFSS6PKWBSS, with icemaker on door. Water is collecting under Deli-draw and leaking down freezer door onto floor. How do I fix leak?
    Try and access the ice dispenser assembly and check from where the water is leaking. You would need to disassemble the ice dispenser and ice maker to check this. The ice dispenser is located in the upper portion of the freezer compartment. This assembly stores ice made by the icemaker and dispenses ice on demand from the door dispenser target switch.
    1. Remove the upper ice bucket tray.
    2. Slide out the ice dispenser assembly.
    3. Remove the ice cube solenoid linkage Phillips head screw and slide the linkage back.
    4. Remove the ice crusher cover Phillips head screws (2) and remove the cover.
    5. With a pair of pliers, twist off the backing plate tabs located on either side of the crusher.
    6. With 2 small flat-blade screwdrivers, unlock the ice crusher locking tabs located at either side of the ice crusher.
    7. Lift the ice crusher out of the bucket.
    8. Remove the ice crusher back cover.
    9. Remove the locking ring from the ice crusher auger.
    10. Remove the plastic nut with a pair of pliers by turning it clockwise.
    11. Remove the spacers and blades. The blades are numbered for reassembly.
    The icemaker is located in the upper rear of the freezer compartment and supplies ice to the dispenser tub.
    1. Disconnect the icemaker cable connector.
    2. Remove 1/4-in. icemaker mounting screws and slide out the icemaker.
    This refrigerator is equipped with an Electronic Icemaker.
    Hope this helps... Please post back if you need more information.
    May 01, 2011 | Refrigerators
    Whirlpool IceMagic Plus not working.
    Pour about 2/3 cup of water into the ice maker . If it dumps the ice but doesn't refill , replace the ice maker . If it doesn't dump , and the cubes stay in the ice maker , replace the ice maker .
    The switch on the icemaker for normal , runs the icemaker normaly . In the ice plus , a small fan comes on , blowing the inside air , over the ice maker mold , to help it freeze faster .
    Sep 14, 2009 | Refrigerators
    Why is the ice maker not droping ice / Mod. ET1FTTXKQ00 / Type C21TFA01 Whirlpool 08-01
    Take a 4 inch piece of 14 gauge insulated wire and strip 1 inch of insulation off each end. Bend the wire into a U shape.Remove the plastic cover from the front of the icemaker. Insert the bare ends into the terminals marked T and H on the face of the icemaker. The wheel should move and dispense the ice into the bucket. If it does not move and drop the ice replace the icemaker.
    Aug 30, 2009 | Whirlpool Refrigerators
    Ice maker wont make ice
    Put about 1/2 cup of water into icemaker . If it freezes and dumps , replace the water inlet valve . If the ice stays in the icemaker , replace the icemaker . Also , make sure the fill tube to icemaker is clear of ice and the coils under refrig are clean of dust , lint , etc..
    Aug 12, 2009 | Roper Refrigerators
    Icemaker does not make ice after first harvest.
    theres whats called a cam inside of the ice maker and that is more than like;ly the problem. you can but your own ice maker from place like first service. good luck.
    Jan 30, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
    Icemaker doesn't make ice
    If there are ice cubes in the icemaker sitting there waiting to be dumped then the icemaker is bad. If the icemaker is dry then it could be the water valve is bad.
    Dec 16, 2008 | Whirlpool 25.6 cu. ft. Side-by-Side...
    Sub-Zero 632 / S Logo
    182 people viewed this question
    Top Sub-Zero Refrigerators Experts
    Charles T Nevin
    Charles T Nevin
    Sal De
    John Tripp
    John Tripp
    Are you a Sub-Zero Refrigerator Expert? Answer questions, earn points and help others
