Question about Dell UltraSharp 1800FP 18.1" LCD Flat Panel Monitor
Dell 1800fp dead
Monitor went blank several times during the last week or and then suddenly went out. The monitor has power to it no indicator lites are lit.
A spare monitor was connected to the desktop its power lamp lites but its screen is blank versus the other which is totally dead. Video Card, motherboard?? Or the monitor and the aforementioned?? HELP
  • rmadhse Nov 30, 2007
    On the surface that makes sense however if the monitor is causing a problem I would now have two computers not working instead of one. I had this checked out by a PC Tech it is the monitor only nothing else.
    Again installing a monitor thats bad on someone elses machine if its shorted you risk cause similar damage to another machine.
    The computer starts fans are on hard drive is running. The second monitor I tryed on the computer just plain didnt work for some unknown reason. I had a PC tech check it out it turned out to be the monitor only all testing was done without using the old monitor.
    Novelist:
    Champion:
  • 244 Answers
If you have friend maybe you can borrow for a while to check either your monitor having problem or the video card. If your power of the monitor still OK possible the problem is came from your video card.
Please let me know any update. I am here to help you.
Posted on Nov 26, 2007
  • Cheater Cheater Nov 26, 2007
    Try to replace borrowed monitor If the problem goes the same the problem was in your video card.
    Novelist:
  • 150 Answers
Each monitor has a different response to "no activity" from the system. So for the monitor, if you get a chance, try your monitor on another machine that you know does function. At work, neighbour, or other.
For the computer, does the it (beep) or POST (Power On Selft Test) when you turn it on, do you see and hear what you would if the monitor was connected?
If it sounds normal, then everything should be fine and luck might have it, your backup monitor is not working either, try another one from the same friend or neighbour above.
If it doesn't POST, you could have a video or other card or ribbon connection loose in the computer. Either you or a friend, or the service center, whichever feels comfortable reseating all the external and internal equipment, bearing in mind static electricity and proper handling measures for the computer.
Suddenly just lost all power...dead.
These monitor had a problem with there power supply. I have 2 of these and both had same problem . If you go on e-bay you should still find people who will fix just the power supply or sell you a kit or for that matter just the one ic that causes the problem . (you would replace bad caps you self) If you replace just the bad caps you will find it still will not work with out that ic
Feb 06, 2011 | Dell UltraSharp 1800FP 18.1" LCD Flat...
Dell 1707FPt monitor doesn't display
Make sure you have the plug in tight or maybe your need a new monitor
Jan 13, 2010 | Dell UltraSharp 1800FP 18.1" LCD Flat...
My Dell 1800FP monitor went black
Confirm your cables did not work themselves loose. Try using a different power cable to confirm that it was not the cable. Finally try a lamp in the socket you are using for the monitor power cable, if you are not using a power bar but even then just to rule that out. If the only thing left is that your monitor is dead, you will need to recycle that one and purchase yourself another one. Sorry
Sep 26, 2009 | Dell UltraSharp 1800FP 18.1" LCD Flat...
1800FP image distorted
this is a little known porblem Dell has. Dell is not tell anybody.
I don't know if this is going to fix the monitor for the long haul, but it should help in the mean time.
grable the frame of monitor with both hands, apply some pressure, not too much (you will break the glass). change location and do the same thing. the screen will come back at certain location, when you apply the pressure to the frame. this is because some connection inside of the frame is coming loose with time.
good luck
if that doesn't fix the proble, please post.
Oct 17, 2008 | Dell UltraSharp 1800FP 18.1" LCD Flat...
Dell LCD monitor suddenly loses power
Five years is a long time for an LCD panel. You definetly got your money's worth.
But, if your trouble shooing has led you to this conclusion I can also only conclude that the power driver inside your panel just gave up the ghost.
However, try giving Dell a call, for what's thats worth and see what they have to say.
You might also want to ask this expert "Robotek" what he may think as he is a board troubleshooter and could give you an answer if one is there.
Type this or copy and paste into your browser's address bar:
http://www.fixya.com/users/robotek
And then click on the Ask Me button under his picture.
Best regards,
Worldvet
Jun 21, 2008 | Dell UltraSharp 1800FP 18.1" LCD Flat...
Dell LCD - Power problem
To my knowledge, there is no easy fix. If the LCD is not powering on and your AC adapter indicates there is power, then it is in the circuitry of the LCD assy and your best bet is a TV repairman.
Odds are, that you can buy a replacement cheaper that the cost to repair that one (1800FP is an 18" LCD by the way) You can buy a 19" Wide aspect Dell LCD at Walmart for $199
May 19, 2008 | Dell 1503FP 15" LCD Monitor
Dell 1800FP
What's wrong with your monitor?
Feb 10, 2008 | Dell UltraSharp 1800FP 18.1" LCD Flat...
Analog Dead/DVI OK
Sounds like the video controller board inside the monitor has blown a transistor. They are only about 3mm wide so not easy to spot even if you look closely.
It's a fairly rare fault, though not unknown to happen without reason.
Nov 14, 2007 | Dell UltraSharp 1800FP 18.1" LCD Flat...
Dell UltraSharp 1800FP 18.1" LCD Flat Panel Monitor Logo
122 people viewed this question
Alun Cox
