Question about Onkyo TX-SR605 Receiver
Onkyo TX-SR605 Receiver HDMI Issue
I have my Cable box plugged into my Onkyo Receiver w/ an HDMI cord and my TV also plugged into my receiver w/ an HDMI cord. The message i continue to receive is "STB blah blah. Use Component Setup". Why are the cords working and allowing me to set it up solely w/ HDMI cords?
  • hektor Jan 04, 2008
    I connected a ONKYO Tx-SR605 Receiver to a Mitsubishi 73” DLP TV. My connections were as follows.
    My DirecTV HD box and a Sony Blu-Ray were connected to the ONKYO receiver’s HDMI 1 & 2 inputs. The ONKYO receiver HDMI output was then connected to the Mitsubishi TV HDMI input #1. I did have the ONKYO receiver HDMI output to the TV turned on.
    I also have an Xbox connected by way of the Mitsubishi TV HDMI #2 input, and a Optical Digital cable connected for the Xbox to the ONKYO receiver Optical input #1. This connection was necessary because the ONKYO receiver only has two HDMI inputs.
    This connection worked for about 40 days. Any time we wanted to watch TV, we just needed to be on the TV’s input #1, then switch to the TV’s input #2 when we wanted to play the Xbox. And like I said, this worked great for 40 days.
    One day when we had the TV’s set to input #2 because we were playing the Xbox. Then we wanted to watch a movie so we tries to switch back to the TV’s input #1 to get the signal from the ONKYO receiver the was connected to the TV’s HDMI input #1.
    What had happened id the TV for some reason lost the setup for the ONKYO receiver. It was like it was never their. I tried to do any thing the book had on setting up the connection but The only way I got it to work was to hit the reset button in the front of the TV. After I got it to work again and then I would turn the TV and then back on, or if I were to change the TV’s HDMI input #2 to play the Xbox, and then tried to switch back to the TV’s HDMI #1 it would be lost again.
    Also when I was trouble shooting this issue, I was able to get the TV working with the ONKYO receiver by unplugging the HDMI cable, and then plugging it back into a different HDMI input on the TV. But I would still have the same trouble and the connection would be lost.
    I got the TV to work, but what I had to do is do a factory reset on the TV the connect everything directly to the TV’s HDMI inputs, and then connect the ONKYO receiver by way of a Coax cable to the Digit input of the ONKYO receiver.
    How can I get it to work again using the ONKYO receiver as the hub instead of the TV? Connected the way I have it now, I’m not taking advantage of the ONKYO receiver’s HDMI inputs as well as it’s 7.1 capabilities.
    I think I may have either turned something on or off in either the TV or the receiver, and it is creating the problem. Besides video and sound, it seems they are creating systems so HDMI connected components can control each other by way of the HDMI connection.
    Could something like this be causing the problem? I did try different HDMI cable but have the same issue.
  • Anonymous Mar 31, 2014
    When I hook it up I get a menu after some gymnastics but I can't go anywhere. Also, the power to the apple will go out and the remote won't turn it back on. I have to unplug the apple and reconnect to power it up.
    Problem Solver:
  • 14 Answers
How good are the hdmi cables that you are using???
Posted on Dec 13, 2007
I can't get my back speakers on when I'm watching TV in HDMI. I have a new TX-SR608
What is feeding the video/audio signals to your Onkyo receiver? Are you getting your input from a satellite receiver or cable set top box? Or are you just using you TV with a coax feed from a terrestrial aerial?
You need a receiver that will decode Dolby 5.1 or 7.1 if you want to use surround sound. If you are using your TV as the reveiver and it has that capability then the problem is probably the type of HDMI cable you are using. You need a cable that has 'audio return' - in other words it will feed the digital audio (from your TV receiver) to the Onkyo box. Some HDMI cables do not include 'audio return'.
Check what type of HDMI cable you have.
If you respond with answers to these questions I will be glad to provide more assistance.
Feb 16, 2011 | Onkyo Audio Players & Recorders
HDMI signal cuts out for a few seconds constantly from receiver to television. It does it when switched to cable box and the roku box. Onkyo TX-SR606 Scientific Atlanta Cable box thru HDMI Roku Box...
Mine did the same thing where the screen would go black for a few seconds and then the picture and sound came back. I would try (1) switch HDMI cables, (2) try a different HDMI input in the back of the receiver, (3) try different input in the back of the TV. None of these seemed to work with mine. I finally ended up running the cable box direct to the TV and only run the audio through the reciever via coax or digital. No more problems. I think the HDMI inputs in the back of the reciever have a problem continuously carrying the signal if it is the leaset bit weak.
Sep 08, 2010 | Onkyo TX-SR606 Receiver
The receiver is hooked up via HDMI and after about
user cable box hdmi direct access to tv hdmi input if ok ...receiver need replaced...if sam proble need replaced cable box...
Mar 21, 2010 | Sony STR-DG1000 7.1 Channels Receiver
Hdmi compatibility
Hello, how long is the cable from the receiver to the TV? Thank you, Onkyo USA
May 31, 2017 | Onkyo TX-SR706 Receiver
Picture sound blackout (blink) when cable box/receiver HDMI used
Onkyo service told me, the second timethat I called them, that there is a known HDMI handshake issue with Motorola and Atlanta Scientific cable boxes. The only solution, and it was a solution, is to connect the box through the HDMI 1 port ONLY. All the other (2,3,4) result in blinking/dropping of signal. I did this, changed the cable/satelilte setting to HDMI 1 and all is well.
Apr 12, 2009 | Onkyo TX-SR705 Receiver
No audio sound from HDMI connection from TV to Onkyo 606 amp.
you have the output of the receiver going to the input of the TV?
i believe that you should be running the TV output to the receiver input to get your sound from the TV to the receiver and thus speakers.
the easiest setup is to just run your cable box and DVD player HDMI's into your TV inputs. then run another HDMI from the TV output to the receiver input.
Feb 28, 2009 | Onkyo TX-SR606 Receiver
Connecting TV and DVD for surround sound
HDMI is fantastic in that's the only thing you need to plug in to get what you want.
You'll need two of them however. Plug one end of the HDMI cord into the HDMI "OUT" on the dvd player and the other end of it to the receiver..labeled HDMI 'IN' Then, take the second cord and do that step with the receiver back to your big screen...HDMI OUT to IN.
Surround sound from TV sources only needs a L&R audio cable connected to the receiver input labled TV or MONITOR audio IN. Unless you'd like 5.1 dolby digital or DTS from the television that requires devices that you haven't mentioned owning. In that case you will be able to get Dolby ProLogic and Pro Logic II from stereo broad casted sources on your TV.
Jan 21, 2009 | Onkyo HTR500 Receiver
HDMI f/ dvd, dvr, receiver and tv
best set up if you have all hdmi is to have all your components go into the receiver ie. hd cable box, dvd etc. by using the hdmi output from the player(s) to the hdmi input to the receiver. next use one hdmi cable from the receiver to the tv then your laughing.
good luck
Dec 31, 2007 | Onkyo TX-SR605 Receiver
Receiver won't put out sound to LCD Sharp aquos
I have the same problem with my Sharp Lcd and Onkyo 804. I believe one problem is that the TV can not accept dolby digital or dts digital audio signals through HDMI. It will play sound if it receives a PCM signal through HDMI. You can try switching the type of signal on the cable box settings and on the dvd player. I switched to PCM and got sound through the TV and the receiver. The problem is that PCM is usually only a 2 channel signal and Dolby 5.1 will sound better through the surround sound theater system. I have not found an absolute solution to this yet, but I am willing to not get sound through the lousy TV speakers in order to get top notch sound through the Onkyo.
Nov 12, 2007 | Onkyo TX-SR803 Receiver
Onkyo TX-SR605 Receiver Logo
725 people viewed this question
Top Onkyo Audio Players & Recorders Experts
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
