Question about Cell Phones
Motorola C118 stuck on vibration mode
I need to find out how to get rid of the vibration selection and get ringtones on my phone. I've tried all sorts of things but can't figure it out. please help. Thanks Marleen from Australia
0 characters
1 Points
How do you adjust the volume on the Samsung T255 StraightTalk phone?
Sound Settings
You can customize various sound settings.
Incoming call
Note: When downloading MegaTones® or HiFi RingersTM, charges may apply.
This menu allows you to select a ring melody. Highlight Ringtone and press . Use the Up or Down key to highlight a ring tone or press the Left or Right key to select a file from either the Default Melodies, Voice list, or Sounds folders. Press the Select soft key.
This menu allows you to adjust the ring volume to one of 7 levels plus Silent mode and Vibration mode.
  • Use the Right or Left key to increase or decrease the volume.
Alert type
This menu allows you to specify how inform you of incoming calls. Use the Right or Left key to select an Alert type.
The following options are available:
- Melody: the phone rings using the ring melody selected in the Ringtone menu.
- Vibration: the phone vibrates but does not ring.
- Melody and vibration: the phone rings and vibrates simultaneously.
- Vibration then melody: the phone vibrates three times and then starts ringing.
- Melody then vibration: the phone rings using the ring melody selected in the Ringtone menu and then vibrates.
Message tone
This menu allows you to set up the ringer for incoming messages. You can set the Tone, Alert type, and Repetition.
  • Use the Up or Down Navigation keys to make your selections.
Keypad tone
This menu allows you to select a Beep or a Xylophone for your Keytone and to select the Volume (0-7) that the
phone sounds when you press a key.
Jan 25, 2011 | Samsung T239 Cell Phone
C118 not ringing, on selecting loud on alert, gives feedback on vibration.
try to check maybe your phone is in mute mode or the volume is set too low.
if playing also ringtones, games or your phone doesn't rings when somebody calls you, this could be the problems below.
if it is not in mute mode then most likely it has a defective speaker or loose connection to the speakers. you can check its connection if inside if you can open your phone. but try only opening your phone if you know what you are doing, you might worsten its problem. you can locate the speaker inside, it is like a small speaker and check if it has abnormalities. other than that, don't touch anything else.
(if you have a multi-tester, you can check the speaker itself by placing the red and black probe to each terminals of the speaker and if you hear a scratching sound on the speaker then your speaker is good. if none, then an open defective speaker.)
(WARNING: only open if there is no more warranty on your phone cause opening it can cause your warranty to be void)
dont forget to rate me. Thanks...
bst rgrds
Jan 05, 2011 | Motorola Mobility KRZR K1m Cellular Phone
I can't find my subsidy code for my motorola C118.
you will able to unlock your phone here
They will provide the code when you enter your imei number,you just need to select your phone model and network provider
Dec 17, 2010 | Motorola Mobility C118 Cellular Phone
Handset locked/setting changed
new simcard doesnt support motorola old phone software ,,for that u need to upgrade your motorola mobile jus visit any motorola sservice center and upgrade the mobile software..
Mar 23, 2010 | Motorola Mobility C118 Cellular Phone
Cell cant ring
ur ringtone is in the vibrating mode i guess.... better change ur ringtone to loud or ascending in ur PROFILE.........settings--->profile
Oct 05, 2009 | Motorola Mobility PEBL U6 Cellular Phone
Cannot get Ringtones!
Go to settings, - Ring Styles, - select style - change it to loud, go to detail of loud and select ring volume and increase it to 7.
Jan 09, 2009 | Motorola Mobility RAZR V3
Ringer and vibrate at the same time
just select the ringtone and select the ring n vibrate feature
Aug 31, 2008 | Motorola Mobility RAZR V3
Motorola krzr k1m stuck on vibrate
So my girlfriends phone wouldn't stop vibrating I just threw it on the carpeted floor (throw it somewhat hard, obviously not hard enough to break it).....then the vibrating stopped.....worth a shot I guess if you don't want to go through the hassle of sending it in.
Feb 08, 2008 | Motorola Mobility MOTOKRZR K1 Cellular...
Ringtone/Ringtone "PLAY" function not working
crazzyyy problem...
i suggest take it back wherever you got it!
Nov 07, 2007 | Motorola Mobility MoroKRZR K1m Cellular...
Cell Phones Logo
Top Cell Phones Experts
IT Solution
IT Solution
Are you a Cell Phone Expert? Answer questions, earn points and help others
