Go into set up tv and add channel
SOURCE: Element TV remote control
Our Vizio TV came with the same problem and my husband just figured out how to fix this... Go to menu then TV at the top and go down to skip channel. Uncheck all boxes and this should solve the problem. Hope it helps.
SOURCE: no tv signal on my olevia 232-s12
cable or Ant.. ? after the scan if there is no channels found (0 digital, 0 analog) then try with cable or Ant to see if any of them work.. if they still don't pick up any channels and the whole yellow progress line goes across.. then it sounds like the tuner on the tv is bad.. and the tuner is part of the main-board so the whole main-board will have to be exchange or repair.. contact Amergence technology they are a 3rd party repair center that service Olevia TV's and they will be able to give you an idea on the repair cost..
<<< Amergence Technology number is 866-965-3842 >>
SOURCE: olevia not searching channels
try the following..
Q.
Why are the menu settings that I changed not being saved?
A.
The TV is in Showroom mode. The following steps will help you switch to Home mode.
***Showroom mode is designed for retailers to display the TV and to protect from shoppers changing the settings that are predetermined for shelf display environment.***.
Q.
Why does my TV display "No Signal" or "Channel not in List"?
A.
Channel search needs to run the very first time of use or after the default settings are loaded from the OSD menu. The following steps will guide you through the process.
SOURCE: RCA Universal Remote RCR412BN - Can't add channels on Sony Trinit
Here is a link to what you need!!!
http://www.rcaaccessories.com/rcaaccessories/RcaaccessoriesInfo.do?findManual=rcr412bn
SOURCE: My Olevia Model 427-S11 shows "no signal"
my olevia tv has no sound did i plug in the wrong wire
