May 9, 2014 - Need codes for universal remote model number lm-1079. Asked by paula young on ... 1 how to set code for tv from lm_1079. Was this answer ...Missing: broksonic
Make and model would help a lot here, but many of the controllers on the small remote control helicopters need to be reset after a crash disconnects the link. You do this by turning both the helicopter and the controller off, then turn the 'copter on first and the controller second. When the lights on the 'copter indicate a connection, take the power control lever on the controller and push it first all the way up, and then all the way down. This resets the controller and should enable the link again.
If it's not a faulty remote control the the TV may need resetting by removing the mains plug for a few minutes and then replacing. Many modern sets (which are basically a computer with a tuner) will effectively, like a computer, simply crash. You need to isolate it from the mains by removing the plug rather than just switch it off on the set. Crashes normally result in some of the remote functions not working. This also applies to PVRs and set-top boxes as well. Hope that helps, Mike.
1. Turn TV on 2. Point the remote at tv and Hold SET and TV buttons at the same time and keep pressed for 3 seconds. 3. The LED flashes and the remote control starts the automatic search. 4.The OFF signal is automatically sent to the tv from the remote control. 5. Once the TV switches off press any button except SET to stop auto search. 6. Switch your tv on using the POWER button.
Universal remote controls come with user manual and the additional code list which you can find the list of devices that can be used with the remote control, It depends on the remote control model that you have, each model has own specific quantity of supported devices and codes. If you are able to provide exact model of your Universal remote control we can check for you, Or simply you can search online <universal remote control model> + code
