My 95 monte carlo turns over but wont start. it turns over but it only backfires once n a while.ive changed the oil, new plugs and wires. what could cause that?
Cmashaft or crank shaft position snesors. Find their location and clean them 1st then re-try.
Check the fireing order of your plug wires u most likeley crossed a few wires and put them in the wrong order if u r looking at the front of the vehicle the front 3 cylenders are 2,4,6 starting from the front of the moter and the back 3 cylenders are 1,3,5 and the coil packs should be marked as to wich cylendr they go to if not the startin with the top coil pack the top plug wire pin is num1 and the second is num4 the next coil pack is 5 being the top pin and 2 being the bottem pin on the coil and the last coil pack is top pin cylender 3 and bottem is cylender 6. hope this helps
