Unfamiliar with it, but free manual at the link below might be of some assistance.
https://www.manualslib.com/manual/32999/Crate-Bx-80.html
Crate BX 80 Owner Manual
SOURCE: Changing the output Jack on 1985 Peavey Dyna Bass
If this has active circuitry, one of the wires is the cutoff for the power supply from the battery. The other two are black for ground and either white or red for signal.
SOURCE: Peavey 115 Low hum Low volume from input
The preamp section has a problem. It could be anything in the preamp but is OFTEN the input jack itself. They take a lot of abuse.
Also the insert jack contacts that forward the preamp to the power amp if no external FX are used can go bad.
Additional things are circuit board cracks caused by rough handling and also controls that have had the knobs mashed in which can destroy the potentiometers they are connected to.
SOURCE: Marshall MG100HDFX 100-Watt Amplifier Head. The
You'll have to take it in to get it repaired. From what you described it sounds like you blew the output stage out. You can't run from your speaker output jack into the input jack of another amp. You should go out of the recording out, line out, effects out or in the least case your headphone out. What happens usually is your output transformer short circuits due to a mismatch of impedances. It sounds like you still have a transformer though so you might have gotten lucky. You will need to take it in though. Sorry.
SOURCE: Crate bass amp bt220 limit led is flashing
You can reach the limiting IRRESPECTIVE of where the volume control is set when you have a guitar or other source that has HIGH output.
Guitars that have battery in them with internal amplifiers are an example of a high output guitar. Plain inductive pickups may require the volume control to be set at say 70% to reach limiting.
Please NOTE that the volume control is NOT linear, but is an "audio taper".
Limiting means you are probably driving it too hard. Many learn the hard way when speakers and thee power amp fail.
When the cone is driven too far beyond the pole pieces of the magnet, then the IMPEDANCE of the speaker becomes relatively low and can damage the power amp. The limiter tries to prevent this by sensing the current and or voltage and will back off the gain internally. This causes distortion when it happens.
SOURCE: Crate Bass Amp B100 - No sound.
Do you happen to have another speaker that you could hook up to speaker output? This would bypass the amps internal speaker and lf you get sound from that setup, it would mean either a jack failure or possible internal speaker problems. Please let me know.
