Question about NEC VT460 Multimedia Projector
Problem on Picture
I have a NEC VT460, when switched on without an input signal, I can see on the RHS of picture a large finger print, it is not an actual finger print, it looks like a VIDEO fault, I have re-seated the PCB's but no change, after sometime when on it will slightly reduce, could this be a PCB FAULT?
Re: Problem on Picture - NEC VT460 Multimedia Projector Multimedia Projectors
Thanks, mohammed
Posted on Nov 27, 2007
  • 115 Answers
Pls check the RGB Panels opening physically. that doesn't seems to be a PCB fault.
0 characters
3 Points
Cleaning dust from inside of lens of NEC NP 100
I would try not to touch it much. Having a single smudge or finger print on the lens will look bad on the picture. just use a blow air can or blow on it. If need get a mico fiber cloth.
Feb 01, 2014 | NEC NP-1000 Projector
I cant find the air filter cause im dumb so where is it ?
Look at the photo above. Find the small grill on the right, you can just see it in the photo. Directly below is a narrow cover with a cutout for your finger nail. Insert finger nail and push down. Out it slides.
Oct 26, 2010 | NEC VT460 Multimedia Projector
Sharper image projectors
s video is what i use and you can get a suround system at walmart fairly cheap for the sound.
Jan 14, 2010 | NEC VT460 Multimedia Projector
Picture will not appear from cable box to nec projector
try the signal(picture)first in television.if it is ok.check projector for right input selection.if it is not check your cable company and ask for help.
Dec 06, 2009 | NEC MultiSync VT540 Multimedia Projector
NEC VT460 issue with RGB input saying out of range. Using cable between laptop and projector
Dear please set the resolution of your PC or Laptop ,so that it can give O/P at same resolution as projector. For issue regarding resolution supported by Projector go through manual of Projector.
rakesh Kumar
Network Support Engineer
Nov 12, 2008 | NEC VT47 Multimedia Projector
Auto adjust in progress
1.Pls tell that to which you are connecting the Projector.
2. from the menu, you can cancell, Auto Search.
Pls tell the details of input signal attached if not solved
Jul 14, 2008 | NEC VT460 Multimedia Projector
Double display
Hi yaali
Try using a different cable.
If the problem however persists , then you will have to get the Mainboard either repaired or replaced.
May 17, 2008 | NEC VT460 Multimedia Projector
NEC vt460 Projector have a ghost problem on the screen
Pls Service the LCD Panels of the Projector, Also check the Fly-Eye lens, just next to Lamp unit. This will solve your problem. if it's not then the only solution is Replacement of LCD Panels, But Must check or replace the external RGB Cable first befor doing all this exercise.
Dec 16, 2007 | NEC VT460 Multimedia Projector
NEC VT460 Multimedia Projector Logo
93 people viewed this question
Top NEC Multimedia Projectors Experts
Electro Med Services...
Are you a NEC Multimedia Projector Expert? Answer questions, earn points and help others
